Solid SRS Light
Old May 29, 2018 | 07:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take your console apart and get the model number off the diagnostic unit in your vehicle. When I say "generic" I mean it was used on a lot of Nissan's, it's still a very exact piece of equipment but they are plentiful. Fortunately there is no reprogramming on it either, just plug and play.
I should note that anytime you install ANY new components onto a vehicle SRS system you always make sure everyone is clear of the vehicle before starting the car. Typically I set the seat back as far as possible before removing the components so when you turn it on the first time you aren't popped at close range by the airbag just in case something goes awry, remove safety glasses and anything else that could hurt you like that mountain of gold chains and ornaments around the neck, etc.
Old May 29, 2018 | 08:33 PM
AnonG35's Avatar
Thanks for the heads up.
I’m going to lay on the floor and turn the ignition on just in case.
And what am I doing or looking for with the # I have on the module? (Nevermind, I see the model number of the new (used) SRS module should have the exact same # as mine.)
Old Jun 4, 2018 | 06:33 PM
AnonG35's Avatar
So I bought a used SRS module from EBay.
It got rid of he solid light. Now I’m faced with a flashing light.
I’ve put it into diagnostic mode (I think), but I was really looking forward to being able to just reset the light so I can just pass this damn inspection 🙄
Old Jun 4, 2018 | 07:15 PM
cleric670's Avatar
BANNED!!!
Try the reset, it's very similar to the diagnostic mode but it just forces the system to go through the new install setup. Try it multiple times.
https://g35driver.com/forums/repairi...g35-coupe.html
Old Jun 4, 2018 | 07:20 PM
cleric670's Avatar
BANNED!!!
Ohh I just watched the video, I can't fully tell but it looks like its flashing THIS pattern while in diagnostic mode.
Old Jun 5, 2018 | 02:32 PM
AnonG35's Avatar
Where is the wiring harness connection located that I should be checking?
Old Jun 20, 2018 | 04:41 PM
AnonG35's Avatar
Bump. Anyone else with any insight?
Could I possibly use a resistor to get rid of the light?
Old Nov 7, 2019 | 07:36 PM
Justin Baker's Avatar
stock G35 Coupe
Did you have to get a module that matches the numbers on your old one? Or did you buy any module on ebay?
https://youtu.be/8mTsXrMSfvQ
Old Nov 7, 2019 | 08:37 PM
AnonG35's Avatar
Yes. The number has to be the exact same.
Old Nov 7, 2019 | 08:51 PM
stock G35 Coupe
i have the same exact problem, a solid light, have you fixed the light yet?
Old Nov 7, 2019 | 11:59 PM
AnonG35's Avatar
I havent man. Just been riding around with it blinking.
On the other hand, I did go to orielly auto parts & get it checked with a OBD2 scanner.
Two srs codes came up that ive been too lazy to fix came up. Hope this helps.
Old Mar 11, 2020 | 06:38 PM
AnonG35's Avatar
I'm seeing 2 flashes, but i'm not sure about which code it could be?
Old Mar 11, 2020 | 08:55 PM
cleric670's Avatar
BANNED!!!
Looks like front LH airbag pattern to me, write it down on paper with times for the flash or record the ENTIRE THING. Remember it will show multiple codes back to back.
Old Mar 14, 2020 | 08:10 PM
AnonG35's Avatar
Okay, FINALLY got all of the SRS light off!
However, I just scanned the car to double check all of the codes were gone from yesterday and now I have code C1145 (Yaw Rate Sensor Malfunction).
I notice yesterday pressing the brakes would shutter really bad when going around a corner or going into my driveway. The "SLIP" light stayed on as well today.
Could this code due to me changing the steering clock sensor or airbag?
Old Mar 14, 2020 | 11:19 PM
  #30
cleric670's Avatar
BANNED!!!
Clock switch also has the steering angle sensor. It's fairly common to need the dealership to reprogram your steering angle sensor position.
If you are tech-savvy and have a laptop you can buy the interface cord and the Nissan Datascan 2 software and do it yourself. It's a worthwhile investment if you plan on digging into the G in the future.
http://www.nissandatascan.com/
