P0442 EVAP control system how to fix??
Old Jun 5, 2018 | 08:50 AM
jezriel adorno's Avatar
New to the forum so not sure if this question has been previously answered but my “service engine soon” light turned on and when I further read into this error code I only found that the problem could be a leaky gas cap or a faulty EVAP canister vent. The prices in both aren’t too crazy but I don’t want to spend 70$ on a vent and it turns out to be just a leaky gas cap or visa versa. Anyone have this problem? the error code is P0442
Old Jun 5, 2018 | 02:32 PM
SoCal04G35's Avatar
a gas cap is $7...give it a shot
Old Jun 5, 2018 | 10:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Many times it's just the gas cap didn't get screwed down until it clicks, reinstall the cap, clear the codes, see if they come back.
Old Jun 5, 2018 | 10:53 PM
ScraggleRock's Avatar
If you want to be absolutely sure, you've gotta get an EVAP smoke test where they hook up a smoke machine to your EVAP system and wait to see where smoke is coming out.
Luckily, this won't affect anything else, so you don't need to be in a rush. Also, in CA you can even pass smog with it by removing your negative battery cable for a few minutes (to reset your CEL), then drive around for about 25-40 miles and go to the smog station. Smog stations don't test for EVAP leaks on OBDII cars. I know this because my other car has a similar code, but it's the fuel pump/gas tank gasket and I quite frankly don't want to drop my gas tank, and it otherwise doesn't affect anything.
Old Jun 9, 2018 | 03:14 AM
Just ended up being the gas cap appreciate the help guys!
Skyfox16
41
Apr 2, 2021 07:13 PM
jessex35
Jun 4, 2018 09:51 PM
silvG35
Feb 18, 2014 07:34 PM
PearlG35x
Apr 28, 2009 12:58 PM
PegG35
Apr 5, 2009 09:57 AM
