How do you remove the @#$%& fan relays?
Old Jun 20, 2018 | 01:10 AM
Kennycaine's Avatar
Maybe I'm missing something. Most relays have a tab that you can jimmy with a flathead screwdriver whereas some have a ridge that you can grab with a fuse puller and pop out. Those three relays for the low, off and high fan speeds are not moving. I know you can't yank them out or something will break but even my mechanic could not see how to remove them. I know someone here has an answer as its not even on YouTube.
Old Jun 20, 2018 | 04:47 AM
Blue Dream's Avatar
I drove ttrank's car solo
Try this:
Looks like in this picture the relay has tabs on the side that would need to be removed from a clip. Not sure if your relays look the same but it's worth a try.
Amazon Amazon
We're having torrential rains here or I'd go outside and visually check it out to see what's up. GL
Old Jun 20, 2018 | 10:25 AM
victor0206's Avatar
Video is helpful. They do have tabs last summer when I had to replace one that was stuck open I remember pressing on the tab and I believe since it was a bad one anyway I ended up using pliers to hold and pull. They were on there pretty tough since they probably haven’t been removed in a long time
Old Jun 20, 2018 | 11:39 PM
Kennycaine's Avatar
Try this: https://www.youtube.com/watch?v=zyRW79kWdAI
Looks like in this picture the relay has tabs on the side that would need to be removed from a clip. Not sure if your relays look the same but it's worth a try. https://www.amazon.com/Genuine-Nissa...ssan+fan+relay We're having torrential rains here or I'd go outside and visually check it out to see what's up. GL
I will give it another go but I tried putting a flathead against it but nothing. Maybe they have been there for 12 years and are stuck on. They are on the firewall and there is no clear-cut tab visible.
Sac2904
May 22, 2023 10:15 PM
ImportPartsPro
Suspension-Vendor
96
Sep 2, 2015 12:31 PM
Sac2904
Dec 11, 2010 01:35 AM
MorenoEnNYC
Jan 17, 2005 03:51 PM
