Did I Just Buy The Wrong Brakes And Rotors??
Old Sep 28, 2018 | 09:10 PM
twentyeggs's Avatar
I just bought 4 brakes and rotors off amazon for my 2004 G35. I accidentally put in 2006 in the fitment section. However i have a 2004. I was pretty confident there was no difference when I went back and put in 2004 Infinity G35 and got the words, "IT DOES NOT FIT." Now I'm paranoid. Is there a difference?! Shouldn't something that fits the 2006 also fit the 2004 or did they change the specs on the brakes between the years?
This is what I bought. I know it's a lower quality brand that uses oil in the machining process vs dry machining from the greats like brembo, but I've been using these cheaper brands for 7 years now on my other daily drivers and they do just fine. More bite and less fading than OEM stuff for spirited driving. and I don't track the G like I do my corvette so it's not worth spending thousands on a brake setup that will never be put through it's paces. They are cheap enough to just toss the rotors after two pad changes. But fitment??? Did I mess up?
https://www.amazon.com/Cross-Drilled-Slotted-Brake-Rotors-Ceramic/dp/B017S63PF0/ref=au_as_r?_encoding=UTF8&Make=Infiniti%7C68&Model=G35%7C885&Year=2004%7C2004&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=4&vehicleType=automotive https://www.amazon.com/Cross-Drilled-Slotted-Brake-Rotors-Ceramic/dp/B017S63PF0/ref=au_as_r?_encoding=UTF8&Make=Infiniti%7C68&Model=G35%7C885&Year=2004%7C2004&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=4&vehicleType=automotive
Old Sep 28, 2018 | 10:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Different diameter and thickness. '03-'04 had two options, regular and Brembo, '05+ had I think one option.
Old Sep 29, 2018 | 01:59 AM
Magneu's Avatar
5 Year Member
G35C 5AT
Adding on to what Cleric said, G's before 2005 had either smaller brakes or Brembo's; IIRC the only way to get Brembos was to have a manual car with the sport package.
For 2005 they swapped to ALL cars having beefier brakes (seriously check out a G's front caliper vs a random car on the road, it's bigger than some SUV calipers I've seen), but also dropped the Brembo's (people didn't like how pricey rotors were.
Old Sep 29, 2018 | 11:10 AM
cleric670's Avatar
BANNED!!!
2003-2004 non brembo outer diameter = 296mm
2003-2004 brembo outer diameter = 324mm
2005+ outer diameter = 318mm
There was also a variation in thicknesses but the outer diameter is the easiest to check.
Old Sep 29, 2018 | 08:35 PM
twentyeggs's Avatar
Great, So I'm going to have to return them.... well that really sucks.. Anyways, thank you for the information guys.
Old Sep 30, 2018 | 04:35 PM
LoSt180's Avatar
05+ had 320mm rotors and 2 piston calipers in the front.
03-04 base (and 05 AWD) brakes were single piston front calipers, and some little baby rotors.
06 pads & rotors won't fit an 04, unless you swap out the calipers also (which is a common upgrade).
Old Oct 1, 2018 | 12:09 PM
MooseLucifer's Avatar
5 Year Member
blk
It may also be worth finding 05-06 calipers and fitting the rotors you got, as the 05-06 brakes are a lot better than 03-04 non brembo. They can usually be found for cheap and will bolt right up.
Old Oct 1, 2018 | 04:50 PM
cleric670's Avatar
BANNED!!!
Calipers and a set of pads for it.
Old Feb 19, 2023 | 02:20 AM
kgsunga's Avatar
G35 Coupe
where can i buy pads and rotor for brembo brakes?
Old Feb 19, 2023 | 11:25 AM
Scorpi0's Avatar
What about these? These might work without having to change calipers.
Amazon Amazon
G35_916
Jul 7, 2012 06:53 PM
Golfer622
Apr 2, 2012 06:11 PM
TheCrescent
Jun 9, 2010 01:25 AM
Omi
Florida G Club
20
Jan 8, 2008 11:23 AM
Nappy
Nov 18, 2007 08:06 PM
