High rpm idle.
Old Oct 14, 2018 | 12:26 PM
John101300's Avatar
Black g35 coupe all stock with straight pipe
High rpm idle.
My idle is sitting a bit above 1000 maybe 1200 . What could this be ? I recently changed my spark plugs and coil on cylinder 5. Also cleaned my throttle while doing so. Any help? Engine light comes back to say “ idle air control valve” but cant find that on the car 🤦🏽*♂️ Please help!!
Old Oct 17, 2018 | 11:20 PM
Mignav01's Avatar
I know the butterfly valve can be really touchy in the throttle body. If you messed w it that's where my money would be as to the cause of the problem. Just Google how to reset the throttle body
Old Oct 18, 2018 | 12:36 AM
coffeysm's Avatar
You probably have the 507 high idle code and it's due to moving your throttle boy valve. Look up "pedal dance". Then prepare to spend a long time yelling, cursing, and hoping it works.
Old Oct 18, 2018 | 04:07 AM
Kennycaine's Avatar
You are going to have to do the idle speed relearn. Some say that it will eventually reset itself but that hasn't been my experience. I kept getting the P0507 code until I did the relearn about 7 times. Then it took and its been 650-700 every since (with AC on).
g0tb00st
V36 Engine, Exhaust, Drivetrain & FI
14
Jul 15, 2011 04:08 AM
HEYrooster
May 12, 2011 08:39 AM
azt108
Mar 14, 2010 12:47 AM
bythabay
May 13, 2006 05:31 PM
Wanchu83
Jan 12, 2006 04:46 PM
