Radio battery drain
Old Oct 16, 2018 | 01:28 PM
jimmyisalcedo's Avatar
Radio battery drain
04 g35 coupe auto 123k miles
just picked up a g35 with the aftermarket double din and wen I bought it I noticed when key was off the power light on the aftermarket radio stayed on. I thought it was normal but 3-4 days later the car won’t crank. The first thing that came to mind was the radio, I don’t think It fully turns off wen key is turned and removed. The power button on the radio stays lit and I can hear a small hiss meaning there is power running through it still ....what can I do to fix this issue ? I can remove the trim and disconnect the radio but it’s crucial to have music !!!
Old Oct 16, 2018 | 03:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wire it up properly, or pay a stereo shop to do it for you. There's a sticky in the AV sub-forum with the proper wiring.
Old Oct 16, 2018 | 11:15 PM
ok thanks , no way I’m going to shop for this lol rip offs.........so I went into the fuse box located in battery area , I removed fuse 15A which is for radio and the light now turns off wen key is off !!!! And I got my battery recharged at autozone , solved my own issue.
Old Oct 17, 2018 | 09:54 AM
Urbanengineer's Avatar
Perhaps you just run a relay to that circuit, so when switched power comes on your "power wire" to the radio switches on with the key. Then you get your radio back and the draw is GONE.
Old Oct 17, 2018 | 11:55 AM
cswlightning's Avatar
Yeah bypass it with a relay... Or if you didn't want to even go that far, a switch to manually cut power to the radio...
Old Oct 17, 2018 | 03:01 PM
good idea. A big annoyance with aftermarket radios is they don't often have a true off button. Just standby. There are times I want to commute in pure silence.
KsuMax
May 15, 2009 01:44 AM
yapper
V36 Audio, Video & Electronics
34
Jul 18, 2008 09:22 PM
joedaddy1
Feb 29, 2008 01:29 PM
