AT Check Light??
Old Nov 15, 2018 | 08:28 PM
Turner8's Avatar
G35
AT Check Light??
Hey guys I was driving my g last night and a light that I have never seen before came on and it said AT Check? So I Pulled over turned off my car then tried to start it and didn’t start again till the next day.. What does AT Check mean? I would assume it means Check Automatic Transmission. I have already checked the fluid it’s fine, what else could it be? And why wouldn’t my car start till the next evening?
Old Nov 15, 2018 | 10:35 PM
Urbanengineer's Avatar
There is a stored transmission code get it checked QUICK. DONT DRIVE ANY MORE THAN YOU HAVE TO.
Old Nov 16, 2018 | 09:28 AM
gary c's Avatar
AT questions!
I've only had the Trans Check Light come on once (went into limp mode) since '04 and that was because my fluid was dirty and it was 97 degrees here in SoCal at that time! That was when I was still believing in what Nissan recommends (every 30K mile fluid change) for their transmissions. Now I change my trans fluid about every 18 months. Forget the Infiniti Stealership, have Nissan check your AT and if fluid hasn't been changed, get 'er done! It is odd your car wouldn't start, question to ask Nissan!
Gary
Old Nov 16, 2018 | 12:19 PM
Turner8's Avatar
G35
Gary
I just changed it about a week ago and yes I put the right fluid in Nissan Matic J
Old Nov 16, 2018 | 09:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Failure to start on a hot motor is usually a bad starter solenoid. If it starts fine later once everything is cooled off I would replace the starter.
Old Nov 17, 2018 | 02:43 PM
Turner8's Avatar
G35
can’t be the starter, just bought a brand new one
Old Nov 17, 2018 | 03:59 PM
telcoman's Avatar
Veteran: Army
Have you read the TM section in the FSM?
See page TM-113
Diagnosis DescriptionINFOID:0000000001833517DESCRIPTIONThe A/T system has two self-diagnostic systems.The first is the emission-related on board diagnostic system (OBD-II) performed by the TCM in combinationwith the ECM. The malfunction is indicated by the MIL (malfunction indicator lamp) and is stored as a DTC inthe ECM memory but not the TCM memory.The second is the TCM original self-diagnosis indicated by the A/T CHECK indicator lamp. The malfunction isstored in the TCM memory. The detected items are overlapped with OBD-II self-diagnostic items. For detail,refer toTM-117, "CONSULT-III Function (TRANSMISSION)"
Telcoman.
evident
Dec 6, 2018 02:33 PM
snunez
Oct 27, 2018 03:29 PM
flytim3
Sep 5, 2015 01:23 PM
VQPWNAGE03
Aug 31, 2007 02:19 AM
