Problem increasing height with coil overs
So i recently purchased and installed a set of truhartcoil overs on my 06AT. After install the car was way to low for my liking so I began the process to raise the ride height on the coils. Once i got to about 24.5 inches it seemed lime the sway bar end links were not letting me turn the raising ring anymore. Do i need adjustable end links increase the ride height now?
Are you turning both sides at once? It shouldn't be an issue unless you're only doing one side at a time.
Factory weelarch height is 27.52" front and 27.95" rear so I doubt endlinks are the problem.
denverinfiniti
Aug 13, 2007 11:10 AM
partshipperdave
Wheels & Tires-Vendor
Jul 3, 2006 04:12 PM
