AT CHECK Light but no Codes - HELP!!
Old Apr 30, 2019 | 10:39 AM
bilbobalbo's Avatar
G35 Couple
Hey Guys, I had a battery with a bad cell and while I was turning my ignition on and off very fast my AT CHECK light has come on, but no Check Engine light and no codes when I read it with my OBD reader. Tranmission is now in fail safe mode and won't shift so I took it to a transmission place and after $800 and finding no causal factor of the problem, told me I need a new valve body and TCM and possible trans rebuild. They did the following tests;
Data showed gear changes in road test but gears didn't shift.
Checked Trans fuses, all good
Removed front cowl and checked Trans fuses, all good
Disconnected Trans Connector, Checked B+ and B- as per schematic, all good
Checked KOEO power to connector, all good
Checked voltage on Can High and Can Low Bus Lines at DLC, all good
I don't really want to spend $6K on a 15 year old car. Any thoughts on what it could be or what I could have pooched while cranking the ignition on/off? Any help is truly appreciated!
Old Apr 30, 2019 | 12:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Tow to Nissan for their diagnostic.
Old Oct 7, 2020 | 06:44 PM
Ant2021's Avatar
Stock
Were you able to resolve your A/T issue.
Im having the same issue.
started up pretty quickly and I’m in fail safe mode..
Old Oct 8, 2020 | 12:46 AM
bilbobalbo's Avatar
G35 Couple
Yes, in the end I believe it was the TCM board that went and it was about $4500 Canadian to have fixed. Works fine now.....Good luck!
Markd319
37
Feb 26, 2022 12:02 PM
Ant2021
Oct 7, 2020 08:24 AM
Markd319
Feb 15, 2016 12:19 PM
kaotekxe
Sep 29, 2014 05:27 PM
dragonv
Jul 3, 2011 05:11 PM
