Vibration during acceleration
Old May 14, 2019 | 02:10 AM
EricDJ's Avatar
Hey guys, i have an 03 G35 coupe with 171k miles. The issue here is that i'm experiencing a slight vibration underneath the pedal as soon as i hit 60 to 75 mph. The sound of it is not extremely loud and it makes a thud... thud.. thud.. sound. Could it be that the driveshaft is going bad?
Old May 14, 2019 | 12:13 PM
TokkioDrift's Avatar
04 6mt Coupe - motordyne 5/16 ART pipes TDX2; KWv2; Hotchkiss; custom seats.
Could be a lot of things.
Either take it to a local shop to diagnose, or do a process of elimination starting with better defining the conditions that the vibration presents.
Since you say vibration is felt in gas pedal and this isn't a X model = rear end.
If you can safely get the car up to speed and then coast in neutral for a short time - the vibration will stop if its input related: trans/shaft/diff/axles.
If the noise/vibration continues with no drive input would suspect out of balance or not round tires, bent wheel, poor alignment, or wheel bearing.
Old May 14, 2019 | 05:52 PM
Galo's Avatar
'06 AX6 G35 Coupe 6sp RevUp 19" Rays RAS, Solar Yellow '01 MR2 Spyder w 2ZZ/C60
By "...underneath the pedal...", do you mean the gas pedal, from the firewall or floor board? Does the noise come from any other locations, i.e underneath the brake or clutch pedals, near the trans tunnel? Does your area/city have any quality chassis shops?
As already stated, you should have it checked out professionally. Be safe!
Old May 19, 2019 | 09:49 AM
EricDJ's Avatar
Found out the culprit to the issue.. The ball joints are completely shot and will be replaced asap!
cpufreak3
Mar 2, 2022 03:35 PM
g35_ifty
Mar 15, 2011 05:48 PM
NeoValentine
Feb 18, 2009 11:08 AM
fast lane
Nov 26, 2007 01:38 PM
whyjay91
Sep 26, 2006 12:36 PM
