Locked out of 2004 G35 6 speed Please Help
May 28, 2019 | 09:28 PM
I've gotten myself locked out of my car and quite the predicament. Please help with suggestions. Here are the parameters:
model: 2004 g35 6spd 2 door
current situation:
-car parked in public parking lot (no risk for tow and small daily fee)
-key and key fob locked in trunk (I do not have a spare, both passenger and driver side doors locked and oem alarm armed)
-BIG FACTOR the current trunk release button does not function (so if i were able to get the doors open I could not pop the trunk open using the dash button)
-I do not have a spare key or key fob that is programmed
what I have:
-triple A membership and drivers license matching the triple A membership
-title and ownership to the car (somewhere in the house)
-a blank key and unregistered key fob (un-programmed and key is uncut)
for sh*ts and giggles i locked the key in myself and realize it is my own doing, any suggestions would be greatly appreciated.
after posting here and hoping for suggestions, will get onto google and download the owners manual to figure out how to get into the trunk from the backseat.
Any suggestions on how to solve my problem is greatly appreciated!
Thanks!
May 29, 2019 | 09:09 PM
Once you're in the cabin back seat dig around in the very middle where the seat and back meet. You'll find a RED NYLON PULL ROPE tucked in there that is the release for the seat back to make it fold forward.
The easiest way into the cabin is the small window behind the door, you'll need stick to reach in (carefully there will be broken glass glued around the edge still) and unlock the door with the UNLOCK BUTTON. If the battery is dead you'll need a hook on the stick to unlock the door lock manually and then pull the door handle from the inside.
The alarm will trigger once the door is opened, pressing the unlock button on the fob will silence the alarm. You will also likely need to use the key to unlock the door or put the key in the ignition for 5 seconds on, 5 seconds off, 5 seconds on, 5 seconds off 5 seconds on, 5 seconds off. This will release the NATS/IVIS bypass on the ignition so the car will start.
A locksmith MIGHT be able to slim jim the door but I have a feeling you're going to end up shattering the glass, use a glass breaker, it's easy.
Call around first to get a quote on that glass, it might actually be cheaper to just knock out the passenger door glass.
