Using Front Fenders as Patch Panels for The Rear Quarter Panel Wheel Well Arch
Old Jun 20, 2019 | 11:32 AM
fcp4life's Avatar
04 G35 Coupe Black Obsidian 6MT / Brembo Brake Package
Exclamation Using Front Fenders as Patch Panels for The Rear Quarter Panel Wheel Well Arch
Considering purchasing a pair of new steel front fenders cut/shape them and weld those in as a patch panel in order to fix the rust around both of the rear wheel well arches. They seem like they would fit if used as a patch panel arch wise. I can't find any information on the measurements / dimensions of the rear quarter panel fender and the front fenders so if anyone knows it would be much appreciated. The guy at one of the shops I went to suggested this as he came out for an estimate.
I attached some pictures to get an idea.
Front Fenders
Front Fender Wheel Well
REAR QUARTER PANEL FENDER
Rear Fender
Rear Fender
SIDE VIEW
Side View
Side View
Old Jun 20, 2019 | 11:43 AM
Urbanengineer's Avatar
Interesting idea. I wonder if it's possible.
Old Jun 20, 2019 | 12:52 PM
fcp4life's Avatar
Seems as it can work. Here are some more angles....
FRONT
REAR
Old Jun 20, 2019 | 03:43 PM
cswlightning's Avatar
Take a rubbing or some measurements and overlay... Would be nice if this worked
Old Jun 21, 2019 | 08:31 AM
fcp4life's Avatar
what more would I be able to do myself to bring the cost down? sanding / striping the rust & paint away in those areas?
Old Jun 21, 2019 | 08:57 AM
Cutting it out and repair with Bondo b
Old Jun 21, 2019 | 10:46 AM
fcp4life's Avatar
In terms of having the patch panel put in. I ordered a pair of steel front fenders brand new for $200
Old Jun 21, 2019 | 12:35 PM
I mean, you could pull your rear bumper and cut out all the rust with a grinder
Old Jun 22, 2019 | 12:04 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
QP skins are usually only about $150 apiece, call around to some of your local body shops and get a price on the metal if it's something you feel like tackling yourself. If you can weld, grind, and sand then it's definitely something you can do yourself. Once it's super smooth just take it in for paint.
Old Jun 22, 2019 | 12:07 AM
cleric670's Avatar
BANNED!!!
Also check any local pick-n-pull. Usually you need permission to oxy-acetylene body panels off but I've gotten stuff like that for under $100 before. They're mostly just concerned about you starting a fire and will require you to have an extinguisher and sign a liability paper.
Old Jun 23, 2019 | 01:33 PM
fcp4life's Avatar
I just got the pair of front fenders in, I was searching everywhere, I couldn't find a fabricated rear fender patch panel as they do with some vehicles, and most shops wanted me to get if not both quarter panels, atleast the driver side one. I don't have experience with welding, but I've cut metal and used a grinder. How much you think this job will cost if a shop cut, welded, grind, and used the front fenders as the patch panel?
Old Jun 23, 2019 | 03:40 PM
cleric670's Avatar
BANNED!!!
Front fender will likely have a different contour but anything can be done for the right price. I would imagine 10 hours per side to have it in a condition that's ready for paint, that's why folks typically sell the chassis and buy another one unless they're doing the work themselves. 10 hr labor x $100/hr = $1000 per side not including paint.
Old Jun 27, 2019 | 10:24 AM
fcp4life's Avatar
Here is how the replacement front fenders look like against the rear.
ALBUM LINK
Album Link (Click Here)
Old Jun 27, 2019 | 12:52 PM
Dang that's not far off at all.
Old Jun 27, 2019 | 03:02 PM
fcp4life's Avatar
Just got an estimate $800 each side cutting welding sanding painting
