2004 g35 clunking noise on front passenger side
Old Jul 15, 2019 | 12:02 AM
Patricklamigo's Avatar
Boosted
I started hearing a clunking noise about a week ago i dont know what’s wrong with it, who ever had the same problem let me know how to fix it
Old Jul 15, 2019 | 12:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It could literally be anything on that corner, strut, ball joint, wheel bearing, bushings, tie rod end.
Get it up in the air and start pulling on stuff until you can replicate the sound. If you have 125k or more miles on the chassis then it's due for a complete suspension overhaul.
Old Jul 21, 2019 | 02:16 PM
gary c's Avatar
Patrick, welcome to the G35 Driver Forums!
Clunking noises generally mean worn parts, I recommend finding a independent alignment/brake shop in your neighborhood! Ask your local auto parts manager who he recommends. You could tear your suspension apart and still not find what's making that noise, suspension people like I recommended will locate your issue in minutes...that's their job!
Gary
Old Sep 11, 2019 | 07:42 PM
Bmr911's Avatar
5 Year Member
G35x
Compression rod is the most likely culprit,
Sway bar end links
Ball joint
Control arm bushings
Even break hardware can cause clunking
hoon
Sep 29, 2017 10:39 AM
keithk831
May 6, 2013 09:11 PM
Tangerine
Jul 31, 2011 07:05 AM
rmeman
Jun 8, 2011 02:56 PM
alliedtech
Jan 21, 2010 01:52 PM
