Where is the power window fuse and is there a single fuse or two of them?
Old Aug 23, 2019 | 05:20 AM
Kennycaine's Avatar
Yesterday my passenger side window stopped working and there was no prior problems. The previous owner said that the motor had been replaced so before diving into it I wanted to get some heads-up. Clearly its not in the fuse compartment on the lower left so that leaves the engine bay. If there is only one fuse for both then that means a new motor since the drivers side works fine. I'd rather know beforehand that I simply need to replace the motor rather than removing the trim covers only to find that there is only one fuse and its fine. I figure its in the fuse box next to the firewall that has the fan and ac relays but knowing the answer beforehand will save me a lot of time that I can devote to taking the door apart and changing the motor.
Old Aug 23, 2019 | 06:12 AM
Scorpi0's Avatar
There are no fuses directly for the window motor.
Old Aug 23, 2019 | 07:27 AM
telcoman's Avatar
Veteran: Army
Have you consulted the FSM?
https://nicoclub.com/FSM/G35/Coupe/2005/gw.pdf
Grab your multimeter
POWER WINDOW SYSTEM
Passenger Side Door POWER WINDOW SUB-SWITCH OPERATIONWINDOW UPWhen the power window sub-switch is pressed in the up positionPower is suppliedthrough power window sub-switch terminal 8.to passenger side power window motor terminal 2Ground is suppliedto passenger side power window motor terminal 1through power window sub-switch terminal 9.Then, the motor raises the window until the switch is released.WINDOW DOWNWhen the power window sub-switch is pressed in the down positionPower is suppliedthrough power window sub-switch terminal 9.to passenger side power window motor terminal 1Ground is suppliedto passenger side power window motor terminal 2through power window sub-switch terminal 8.Then, the motor lowers the window until the switch is released.POWER WINDOW MAIN SWITCH OPERATIONSignal is sentthough power window main switch terminal 12.to power window sub-switch terminal 16The operation of power window after receiving the signal is as same as for operating the power window withsub-switch.POWER WINDOW SERIAL LINKPower window main switch, power window sub-switch and BCM transmit and receive the signal by power win-dow serial link.The under mentioned signal is transmitted from BCM to power window main switch.Driver side door switch signal.Keyless power window down signal.The under mentioned signal is transmitted from BCM to power window sub-switch.Passenger side door switch signal.Keyless power window down signal.The under mentioned signal is transmitted from power window main switch to power window sub-switch Passenger side door window operation signal.Power window control by key cylinder switch signal.Power window lock signal.AUTO OPERATIONThe power window AUTO feature enables the driver to open or close the window without holding the windowswitch in the down or up position.POWER WINDOW LOCKThe power window lock is designed to lock operation of passenger side door window.When the lock position, power window lock signal is sent by using power window serial link from power win-dow main switch to power window sub-switch.Power window sub-switch by which the signal is received, prohibits the operation of passenger side powerwindow by power window sub-switch.
GW-18POWER WINDOW SYSTEMEdition: 2004 September2005 G35 CoupeSystem DescriptionAIS001WZPower is supplied at all timethrough 50A fusible link (letter F , located in the fuse and fusible link box)to BCM terminal 55through 10A fuse [No. 18, located in the fuse block (J/B)]to BCM terminal 42through BCM terminal 54to power window main switch terminal 1to power window sub-switch terminal 10.With ignition switch in ON or START position, power is suppliedthrough 10A fuse [No. 1, located in the fuse block (J/B)]to BCM terminal 38, andthrough BCM terminal 53to power window main switch terminal 10Ground suppliedto BCM terminal 52through body grounds M30 and M66.to power window main switch terminal 15through body grounds M30 and M66.to power window sub-switch terminal 11through body grounds M30 and M66
Driver Side DoorWINDOW UPWhen the driver side window switch in the power window main switch is pressed in the up position, Power is suppliedthrough power window main switch terminal 8.to driver side power window motor terminal 2Ground is suppliedto driver side power window motor terminal 1through power window main switch terminal 11.Then, the motor raises the window until the switch is released.WINDOW DOWNWhen the driver side window switch in the power window main switch is pressed in the down positionPower is suppliedthrough power window main switch terminal 11.to driver side power window motor terminal 1Ground is suppliedto driver side power window motor terminal 2through power window main switch terminal 8.Then, the motor lowers the window until the switch is released
Telcoman
Old Aug 23, 2019 | 02:45 PM
FreshLikeAG's Avatar
As dumb as it sounds, make sure the passenger window button isn't pushed in on the driver door master switches
Old Aug 23, 2019 | 04:05 PM
telcoman's Avatar
Veteran: Army
Not dumb!
It is in the FSM operation and most likely described in the owners manual
".Power window sub-switch by which the signal is received, prohibits the operation of passenger side powerwindow by power window sub-switch."
Old Aug 24, 2019 | 05:57 AM
Scorpi0's Avatar
POWER WINDOW SYSTEM
Telcoman
Yeah....good luck with all that.
Rizzagt22
Apr 14, 2022 01:15 PM
seng278
Dec 9, 2011 07:57 PM
BudMan10
Jun 18, 2011 02:15 PM
acemallone
Apr 1, 2009 04:50 PM
TSarra
Nov 3, 2008 04:01 AM
