Oct 2, 2019 | 09:32 PM
Quote: Steering angle malfunction will definitely cause the car to misbehave. Fix that code and see if the problem persists.
Question about those cam/crank sensors you replaced. Did you use Hitachi or Genuine Nissan OEM ones? If not then you should probably replace them because these engines don't play nice with aftermarket sensors.
Another question about the clutch you replaced, did you make sure to get the alignment pin dowel correctly lined up on the crank? It probably wouldn't run at all if you did NOT but it's worth asking.
i used hitachi ones, but the problem started before that
Reply 0
Sep 7, 2021 | 05:32 PM
It ended up being the diode dynamics tail as turn module causing the issue. The amount of money and time i spent trying to figure it out is obsurb but glad its fixed, the only reason i knew was cuz my buddy installed it and had the same issue.
Reply 1
Sep 9, 2021 | 08:58 AM
I have those. Was this causing you power loss, or the steering angle malfunction? Tell me more!
Reply 0
