Can anyone pinpoint this weird squealing / whining coming from engine bay
Old Nov 9, 2019 | 12:58 AM
FahBreezy's Avatar
Angry Can anyone pinpoint this weird squealing / whining coming from engine bay
I recently installed the new intake in the video and can 95% confirm that there is no a vacuum leak coming from any of the connecting areas. Also the water is from the rain night before.
This sound does not happen until the car is up to operating temp, I can start the car up and it doesn't make this noise until the engine is at temp so my guess is a leak in a coolant line?
It has been doing this past 4 days, no driving problems.
https://www.youtube.com/watch?v=A9Bj...ature=youtu.be
Old Nov 9, 2019 | 11:49 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Bad pulley bearing, take both drive belts off, spin them all by hand (not the crank pulley) and see which ones make noise.
It should be PERFECTLY QUIET with a slight bit of resistance, typically you can only get about 1 full revolution out of the idler/tensioners when you spin them by hand.
99% chance it's those tensioner pulleys, I imagine they're going to spin like 20-30 times when you give them a good spin and probably sound like gravel inside.
Also, fix whatever is throwing your check engine light
Old Nov 14, 2019 | 01:57 PM
FahBreezy's Avatar
Thanks for the reply man. Would a bad tensioner pulley also cause overheating sometimes when in traffic? The sound and this problem started right around the same time.
Also the check engine light is for bad cats :"(
DumpsterJedi
Apr 21, 2015 12:22 PM
CLRH2O
Jan 29, 2012 10:07 PM
WhiteonWheat
Dec 26, 2010 10:28 AM
berniEE
Nov 5, 2010 01:45 PM
uteric
Dec 29, 2006 11:12 PM
