Infiniti g35 help
Old Dec 4, 2019 | 04:29 PM
Jackson.eagan06's Avatar
Infiniti g35 coupe
Infiniti g35 help
My G35 I’ve had for about 8 months now and I’m ready to start modifications, I wanna add as much horsepower as possible without having to buy a super charge or a turbo charger. Any idea how I can do so what’s the best starter mods for the car and then once I have those what will really show me a difference in power?
Old Dec 5, 2019 | 12:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
5/16 plenum spacer for non-revup, 5/16 spacer and MREV2 lower intake if it IS a revup motor. HFC, rev-up airbox, tune.
Those are the biggest gains. Exhaust if you want it noisy and a little more power.
Old Dec 7, 2019 | 02:57 PM
fredrik94087's Avatar
maybe things have changed?
IIRC, bread and butter bolt ons were IHCE...intake header cat exhaust.
that was good for about 40whp, right?
I know the plenum spacer helps as well. But there is no good acronym for 5 things.
IPHCE?
Old Dec 7, 2019 | 09:07 PM
herrschaft's Avatar
IPHCE?
Headers were never extremely beneficial, they are mainly for sound. HFC's or straight pipes designed for scavenging and an unrestrictive exhaust will help. Most of the aftermarket intakes I've seen deal with heat soak issues so a good combination is a "Z" tube which eliminates the baffling and using a higher flow drop-in filter with the OEM air-box. The OEM velocity stack off of a Revup air-box will also help slightly. For the Revup, an MREV2 or the lower intake plenum from a DE will benefit mostly in the early part of the power curve. And yes, the spacer is a very good mod for those that don't want to go with an aftermarket plenum.
For those that want to machine out the inlet of the upper plenum and go with a larger throttle body, then a larger diameter intake would be best.
40+ gain with a tune is achievable on the Revup but would be much harder to get with a DE.
cyncrvr
Jan 1, 2018 01:22 PM
devon03G35
Aug 2, 2013 09:37 AM
punkkidd82
Nov 30, 2008 11:32 PM
garry101
Jul 6, 2006 10:51 PM
