Replacement control arm is different than OEM, cant get ball joint to seat properly.
Old Dec 8, 2019 | 03:47 PM
ProphetZae's Avatar
05 g35, RevUp engine
Im not sure what to do here. Do I need to replace the ball joint? Thanks in advance.
Deeper than oem, nut sits far lower on stud
OEM, a lot more shallow, nut sits just under cotter pin
Old Dec 8, 2019 | 04:49 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you sure it's the correct part for your vehicle? Does it have the correct angle cone washer on the ball joint?
Old Dec 8, 2019 | 05:33 PM
ProphetZae's Avatar
The part number is the same and everything else is the same as far as dimensions and fit. I am using the OEM angle cone but it appears to be too tall due to the difference shown
Old Dec 8, 2019 | 05:48 PM
cleric670's Avatar
BANNED!!!
I'd fit just the cone washer in by hand to verify it fully seats. In that first picture you posted the ball joint is clearly not seated fully onto that red colored control arm.
Where did you get this replacement component from?
What was wrong with the existing transverse link? If the inboard bushing was shot you should just replace the bushings.
Old Dec 10, 2019 | 10:22 PM
ProphetZae's Avatar
I had the bottom of the ball joint jacked up trying to get it to seat, I stopped when the ball joint started to ooze old grease haha, and I got the replacement at autozone as they were the only ones with any in stock. The bushings were so destroyed they fell out of the old control arm and it looked like the sockets were destroyed
KARMA_G35
Mar 2, 2018 03:15 PM
cenzo6mt
Nov 7, 2016 01:50 PM
GeeBruce
Dec 27, 2013 08:58 AM
CFernando17
Jan 27, 2013 08:44 PM
Cleanasscoupe
May 3, 2009 01:48 PM
