upper oil pan fatigue fractures?
Old Jan 6, 2020 | 03:27 PM
shurur's Avatar
2003 G35 Coupe
inside pan:
outside pan
There appear to be hairline fatigue fractures at most of the inner form "posts" with some showing on the outside.
There appear to be hairline fatigue fractures all along the pan as well
Is this "normal?
Should I replace the pan?
Are there different revisions of their upper oil pan that are more desirable?
The pan is cast AL5 #1
Old Jan 6, 2020 | 03:34 PM
G2B35AGN's Avatar
Don't use photobucket. Can't see the pics. The URLs don't work on mobile app. Use the forum photo upload tool. They'll be stored on the forum servers and they'll won't go away (like the images in so many old DIYs that are now less than useful).
Old Jan 6, 2020 | 06:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Those pictures only embedded as thumbnails because you probably posted from a 3rd party site. Upload photos directly into the message using this icon.
Old Jan 6, 2020 | 06:28 PM
shurur's Avatar
2003 G35 Coupe
nope not letting me do it.
There seems to be no "ok" button to finally drop the picture in.
Pic shows in the upload window and that is it..nothing there to seal the deal and drop it in the thread.
Might be my ubuntu chrome..but usually not a problem anywhere else I go.
Thanks all.
EDIT: paper clip icon worked for me...
Old Jan 6, 2020 | 08:02 PM
cleric670's Avatar
BANNED!!!
Looks like casting marks to me, left over from the mould.
Old Jan 6, 2020 | 08:18 PM
shurur's Avatar
2003 G35 Coupe
I can see the cast marks, or what I would call posts and indents from the form, but there are hairline cracks that seem to come out from some of those marks. And some have those hairlines on the both inner and outer pan areas.
If the hairlines were raised that would be ok to me, but they are not.
I hate to put this thing back on and have it give way sometime down the road.
Old Jan 7, 2020 | 12:05 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
The aluminum casting looks like this on most of the stuff I have worked on (SR20 & VQ) I wouldn't worry about it unless it was leaking in the first place or a part that was stressed like the AWD upper oil pan after the differential blows up. I could probably take pics all day in the shop and show similar markings.
Old Jan 7, 2020 | 07:20 AM
shurur's Avatar
2003 G35 Coupe
OK.
Well it was leaking along the full length of the the pan.
Most of the leaking was on the ends where the rubber seals had hardened to near plastic like stiffness; I pulled them off in pieces.
You both are probably correct, as I don't really know these cars that well; that's why I am here.
I still "feel" uncomfortable with the pan; so I ordered a new one from Z1motorsports.
I ordered the check valve and have the oil cooler o rings as well.
I just have to see what a new one looks like.
Old Jan 7, 2020 | 09:32 AM
GaryEvans's Avatar
Looks like die casting flow lines created when the part was made.
Old Jan 10, 2020 | 12:13 PM
shurur's Avatar
2003 G35 Coupe
OK..I got the new upper oil pan and as you folks said, those are just casting marks, not fractures.
New pan looks exactly like it in terms of casting mold marks.
I had to find out myself.
I hope this thread helps somebody anyway.
I'll put the new one on her car and sell the other on Craigslist Tampa to someone who needs it.
Thanks again
Old Jan 10, 2020 | 11:27 PM
cleric670's Avatar
BANNED!!!
Usually when mass-producing stuff like that they use permanent molds and those things might have 10k or more castings from the SAME MOLD. Over time the releasing agent builds up in corners and around edges, plus you will always get warping on a steel mold used for aluminum casting. When it gets bad enough that it doesn't pass quality assurance then the mold is recycled.
Old Jan 15, 2020 | 08:48 AM
chasracer's Avatar
This sounds like my own son - someone will say something or he'll notice something and suddenly it's a huge, possible problem. I am all for preventative maintenance but the only winner in this deal was Z1 Motorsports. Why ask questions and post pictures if you are going to make the purchase? That's at least $200 spent on something that wasn't needed - just wait til the driver's side window quits or sensors on the fuel tank give up and on and on....
Old Jan 15, 2020 | 03:25 PM
shurur's Avatar
2003 G35 Coupe
OK So I went with my gut feeling, which is usually correct.
Live and learn.
And It is still a good thread for others who may wonder about what the casting marks look like.
BTW: I have already fixed the DS window and have the passenger side to deal with next.
I don't generally shot-gun parts; although I will replace small things while I am in there.
For instance, I replaced the rubber portions of the power steering return hose while the hoses were accessible.
The upper oil pan is a big enough job that one would not want to revisit it.
Thank you for your input.
ZBigKahuna
May 23, 2016 12:23 AM
Thanhnguyening
Oct 12, 2014 02:27 PM
ryoung81
Jan 9, 2014 10:57 PM
G35xCali
Nov 15, 2012 09:47 AM
str8dum1
Forced Induction
28
Mar 18, 2008 04:36 AM
