PLEASE HELP G35 making loud rattle noise
Old Jan 7, 2020 | 12:28 AM
colt ladd's Avatar
g35
Ok so my g35 started making this loud rattle noise at random times and idk what it is. The vdc off slip and abs lights are on. And I was told it was the abs pump at first and if I cut the two abs bridges on the abs and ignition fuse that it would temporarily fix the problem at least but the noise still comes on at least when I push these defroster button right here still. Soo old I’m lost
Old Jan 7, 2020 | 05:44 AM
Scorpi0's Avatar
Does it only come on when u turn the AC on?
Old Jan 7, 2020 | 04:38 PM
colt ladd's Avatar
g35
no tht just makes it kick on instantly it seems. It still kicks on off an on while driving
Old Jan 7, 2020 | 05:47 PM
Scorpi0's Avatar
does it make noise even when the engine is off? Have u listened to see where the noise is coming from approximately?
Old Jan 7, 2020 | 08:58 PM
colt ladd's Avatar
g35
yes it does happen sometimes when the car keeps running and or making noise when key is out of ignition and doesn’t turn off until I turn my headlights out. And I can’t rly tell where it coming from but I wanna say more toward front of engine.
Old Jan 7, 2020 | 10:26 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Sounds like the cooling fan blade is hitting something. When you turn on defrost it kicks on the AC which turns on the cooling fan.
vad_srikar
Mar 19, 2007 11:15 PM
WhosRich
Feb 20, 2007 07:50 PM
I Scare
Feb 1, 2006 09:33 PM
pcsdca
May 26, 2004 01:20 PM
hyunwoo8521
Feb 6, 2004 10:22 PM
