Full Coilover or Springs??????
Old Apr 5, 2005 | 02:46 PM
g35noob's Avatar
bump i want to know too
Old Apr 5, 2005 | 03:07 PM
sillyhenry's Avatar
with springs or coilovers don't u need camber kits to get alignment up to oem specs so that u don't have uneven tirewear? and that adds to the additional price????? btw i think this thread should be in the mods/tech - wheels, brakes, tires, suspension section
Old Apr 5, 2005 | 07:46 PM
Cactus's Avatar
bumpity bump
Old Apr 6, 2005 | 05:42 AM
enzo's Avatar
Originally Posted by 636Racer
go coil over.
and stay away from the trendy tein :P
try taking a look at silk road coil overs, my friend's shop has been shipping silk coil overs to a lot of 350Z owners.
http://www.silkroad-usa.com/pages/rm8.htm
http://www.munkywurks.com/
how much are silk road coilovers?
Old May 19, 2005 | 04:24 AM
TheGest's Avatar
Gangster Member
Originally Posted by myGspot
The question is ... how often will you be adjusting your suspension set up.
Most people unless racing... would only readjust their suspension a few time to get it just right after installation. ANd then it would be set in that particualr setting.
BUT..... problem with adjusting your suspension hight... is you need to do a 4 wheel alignment as well. So is it cost effective to adjust the hight get alignment and so on and so on.
For those who do shows it could be better... cause they can slam the car down. But again.. cost of doing alignment (unless its a show car then who cares)
Springs are way easier. Just get the desired drop... BUY SHOCKs.. dont wast the time and money doing it later do it all at once. Then you are all set for a long time.
I think a really great set up woul dbe H&R and KONI. or if you go for coilover set up... H&R COIL OVER KIT $$$
I agree but i dont think Koni makes shocks for the G yet, had to bring this thread back from the dead
Old May 19, 2005 | 07:17 AM
LUV2DRIVEMYG35's Avatar
Originally Posted by 1Gig
Coilovers!!
You are going to have to replace the shocks eventually if you go with springs. So why waste money to install springs and install shocks later, double labor cost.
Depends how low you go. I would agree with you for any drop over an inch. Some of us are looking for a mild drop where a realignment can put the car back in spec and you don't even need a camber kit. In such a case, I'd say yes the shocks will wear a little sooner, but not to the point where it's worth going to coilovers. Unfortunately, "i2ob81" didn't mention why he wanted height adjustment nor how much he was looking for.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
EasySausage
Sep 24, 2015 01:06 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
