Exhausts and lateral bracing
Old May 13, 2020 | 08:38 PM
Magneu's Avatar
5 Year Member
G35C 5AT
Hey all, got a problem I haven't seen yet. Got an HKS Hi-Power true dual and Fast Intentions RHFC (zero drone, btw. Great setup) and a Soul Function Rear Lateral Brace. The exhaust is contacting my rear lateral brace ever so slightly, even with all new exhaust bushings (including a stiffer Nismo one at the midpipe mount) and the promise that true duals fit this brace. To be fair, it is a very, very small amount of contact where I get a buzz/rattle only when the engine is fully hot, at idle, in Drive.
What solutions do people have? The steel clamp solution hasn't worked, and I'm close to either grinding part of the brace away or part of the exhaust flange away (contact is the flange from midpipe to driver rear muffler, if it was a half inch forwards it would clear). Anyone ever have this problem and possible solution?
Old May 15, 2020 | 06:03 PM
Magneu's Avatar
5 Year Member
G35C 5AT
Nobody using a true dual setup with a rear lateral brace? Coulda sworn I've seen a few.
Old May 17, 2020 | 03:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would take it down to a muffler shop and just have them relocate that flange, probably cost you about $100.
They can cut out the flange so it has about 3 inches of pipe on one side and 6 inches of pipe on the other side and literally just flip the thing around. That would relocate the flange 3" one direction.
Old May 17, 2020 | 07:45 PM
Magneu's Avatar
5 Year Member
G35C 5AT
Ugh, I was really hoping to not have to cut up my new (to me) exhaust, but what you're saying does make sense...gonna give one more go with cutting a custom hanger and hopefully that does it, otherwise down to the shop we go.
Old May 18, 2020 | 11:16 PM
Magneu's Avatar
5 Year Member
G35C 5AT
Well, I've wrapped both exhaust mount points with some beefy mylar heat-wrapping to increase the diameter/reduce metal to metal contact and used two stainless steel clamps to hold the pipe in place. Yet to test drive, but the piping is no longer hitting my bracing, and is still clear of the differential. Seems to be negligible vibrations entering cabin through the stiffer "mount", but it'll do for now. I think long term is punching/cutting my own custom rubber mount for the height that I need.
Gonna have to stay away from the cutting solution as due to the bracing position, I would need to remove the brace (essentially installing control arms in the rear again), do the work, and re-mount the brace. Waaaay to much work to be honest (plus at least one alignment, depending on distance to shop). Plus, I would hate to irreversibly modify the exhaust.
Old May 22, 2020 | 09:07 AM
cleric670's Avatar
BANNED!!!
It's just metal, there's no such thing as "irreversible"
Cut/weld/grind as needed.
da champ
Engine - Exhaust
Dec 28, 2010 10:39 AM
ShanesG
Intake & Exhaust
18
Dec 19, 2008 10:34 AM
moro310
Oct 7, 2008 06:53 PM
deviant1
Intake & Exhaust
May 12, 2005 12:21 PM
G35driver2
Intake & Exhaust
Dec 11, 2004 04:58 PM
