Weird noise after sandwichplate installation
Old Jun 17, 2020 | 06:16 AM
naiki's Avatar
Skyline v35 6spd manual
Hello fellas. I installed sandwichplate to my v35 and ended up with weird noise coming from plate.
Does anyone know what occurs this weird noise?
I did a little test drive and temps went up to normal so oil is circulating i think.
Could this have something to do with oil flowing troughg the sandwichplate.
(Sorry for bad grammar haha)
I appriciate your answers.
Link to noise
Old Jun 17, 2020 | 10:31 PM
chasracer's Avatar
I'm not too familiar with these however if I took a guess at it, it sounds like a vibration. Are you positive you have everything tightened up correctly? And does your oil pressure read okay?
Old Jun 18, 2020 | 01:05 AM
naiki's Avatar
Thanks for your response.
Its only doing this when warm (oil temp above 50)
And yeah i have checked that everything is okay.
I dont have oil pressure gauge in my system yet
Its coming.
Old Jun 18, 2020 | 09:50 AM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Sounds airy...vacuum leak?
Old Jun 18, 2020 | 11:19 AM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
Is the car throwing any codes since installing this sandwich plate? I assume you mean the intake plenum spacer plate like a Z1?
If you did install one of those you need to make sure you tightened and torqued the bolts down in the right sequence and you got gaskets installed correctly. Also any hoses you might have disconnected.
Old Jun 19, 2020 | 10:28 AM
anynigma's Avatar
Its common for people to pinch the rubber gasket around the oil filler neck when they put the plenum back together. Check that too.
Old Jun 19, 2020 | 11:03 AM
naiki's Avatar
will do, thanks 👍🏻
keithk831
Jun 24, 2013 04:34 PM
McElroy
May 19, 2008 04:15 PM
DaCePtak0n
Mar 8, 2007 01:43 PM
dennyduong
Jul 16, 2005 11:50 AM
