G35 VDC OFF SLIP light on car won’t get out of park
Old Jul 21, 2020 | 01:40 AM
Nathan Dolin's Avatar
03 g35 coupe
Recently i did a wing delete and took off my wing, The third break lights were showing so i just disconnected them. i go to drive my car and it starts but won’t go into drive. any ideas what happened? I tried rewiring the wires and putting the wing back on but nothing worked. idk what to do.
Old Jul 24, 2020 | 03:56 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
How did you "disconnect" them? I would start checking fuses.
Old Jul 25, 2020 | 12:19 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably blew the brake fuse so the ECM doesn't recognize that the brake pedal is depressed and thus won't release the parking lock. You can manually bypass the lock, there is a shift lock release right next to the shifter under a small piece of removable plastic. Then use a small screwdriver or the specialty lock release tool that's mounted in the spare tire well next to the jack.
AaronJP
Jan 22, 2009 01:55 PM
Gfash0
12
Dec 24, 2008 01:21 PM
CanadianZ
Mar 6, 2007 10:56 PM
AthensBlueG
Sep 21, 2006 11:19 PM
