RPMs not going over 2000 RPM on 2004 G35
Old Aug 17, 2020 | 11:01 AM
2004g35@Lft's Avatar
G35
We’re having an issue with the RPMs stalling out under 2000 RPM; it corrects itself but at anytime we are subject to experiencing diminished power.
we did not find an ETC (electronic throttle control) relay or fuse. Any help would be appreciate
Old Aug 17, 2020 | 01:04 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Do you have any CEL codes? If you do, PULL THEM. Cutting out at 2k rpm is limp mode as I recall.
Start with the basics:
-Check/change your spark plugs
-Clean MAF sensor
-Cam and crank sensors are common to fail on these cars -> pull codes!!!
Old Aug 17, 2020 | 08:08 PM
G35
Throttle body
Could the problem be caused by the electronic throttle?
MVMNT
Jan 14, 2016 07:47 PM
flhtvtwin
Feb 19, 2012 10:51 PM
shyger85
Drivetrain
Nov 14, 2011 03:24 PM
xjjangsterx
Aug 3, 2007 03:37 PM
