Spark plug well causing missfire
Old Sep 13, 2020 | 10:58 AM
Siciliang35's Avatar
I changed the valve covers not too long ago maybe a few months and one of them is leaking causing a missfire. Is there any way to get by for a while without redoing it. I'm getting a misfire but no check engine light. Will cleaning it really well get me by.
Old Sep 13, 2020 | 03:11 PM
After taking out the spark plug cleaning the well and putting everything back together and now I got PO113 code this is giving me a headache now
Old Sep 13, 2020 | 03:20 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
For the P0113, check the electrical connection on the MAF sensor, as I think the MAF on these cars has the intake air temp sensor built into it
Old Sep 13, 2020 | 04:14 PM
Yeah I double checked that and I think the code went away after replacing cylinder two ignition coil it's still misfiring but even worse
Old Sep 15, 2020 | 10:27 AM
04.5 G35 Sedan 5AT
Make sure you have the coils plugged into the correct harness connections.
Its very easy to swap the #4 and #6 connections (others as well), thus causing the misfire.
Old Sep 15, 2020 | 12:18 PM
I I think I had my connector that wasn't pushed all the way in I got that taken care of The problem is I got to most likely change the valve cover soon which I already did not too long ago
Old Sep 15, 2020 | 03:26 PM
cswlightning's Avatar
What makes you think it's the valve cover other than recent work done? Have you actually checked and found a pool of oil messing with the connection of one or more of your ignition coils, or wicking down the spark plug threads into the combustion chamber?
TiIngot
Aug 12, 2019 07:41 PM
dat_skyline
Sep 19, 2016 01:05 PM
GeeBruce
May 7, 2013 12:36 PM
Threepoint5
Apr 10, 2012 09:14 AM
dias724
May 18, 2010 01:43 PM
