Help!
Old Sep 29, 2020 | 11:20 AM
KDomfeh23's Avatar
2005 Infiniti G35..just now looking into mods
Help!
I need help. My brake light and battery lights are both on. The car starts as normal but the steering wheel is very stiff; it literally moves 1-inch to the left and 1 inch to the right
Old Sep 29, 2020 | 01:42 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Brake light typically means the E-brake is set, or the little switch is stuck. With some cars that also indicates the brake fluid level is low.
Battery light means there is a fault in the charging system - check the battery terminals and the alternator (you should have 12 to 14 volts engine running, 11 or lower you have a problem)
If the steering is stiff check your power steering fluid on the drivers side of the engine bay. Check for leaks too. The pump can fail/leak.
cruzin831
Mar 6, 2013 01:53 AM
JoeMac
Oct 2, 2010 04:24 AM
STL_G
Apr 29, 2009 10:52 AM
zogan
Feb 23, 2007 12:05 PM
greek211
Jan 21, 2007 02:39 AM
