Transmission Swap HELP PLEASE
Old Oct 7, 2020 | 07:40 PM
Lupe Ledesma's Avatar
Sedan
Can I use a 2004 g35 coupe Transmission on a 2005 g35 coupe?? Both cars are RWD. After putting the 04' transmission in the 05', the gas pedal is having issues. Whole car was lifted, oil was put in the transmission, everything was working fine, put her down and the car won't accelerate. All the connectors are the same, and gas pedal was working fine at first, but then just stopped. Car turns on and idles fine, just the gas pedal/accelerator isn't working anymore. Could the 04' transmission be the problem for this happening? Anybody have any suggestions, or know how to solve this???
Old Oct 9, 2020 | 05:07 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I believe you will need to take the car to the dealership to have the TCM and ECU 'married'.
Some of the early '04 cars (and all 03's for that matter) have the TCM located in the passenger side kick panel, while late-04's (and all 5AT cars from then on AFAIK) have the TCM physically mounted inside the transmission with the valve body.
Since you say all the connectors matched up, I think you just need to have it programmed is all (hopefully)
Old Oct 9, 2020 | 06:04 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I have swapped RE5 transmissions with the built in TCM and haven't had any problems. They are not married to the ECU. The only time you may have a problem is if you get a new valvebody / TCM from the dealer because they are blank and need programming. Sounds like the op has other wiring issues.
Old Oct 9, 2020 | 07:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does the engine rev up when you push the gas pedal or does it not go past 2500rpm?
Blueyedg35guy
V36 Audio, Video & Electronics
Mar 7, 2020 11:43 AM
fblue
Aug 21, 2011 06:38 PM
achau
Jan 19, 2007 11:26 AM
