Heated seat question
Old Nov 25, 2020 | 09:51 AM
cassa183's Avatar
Sorry for another heated seat post. I have been lurking for a while now as I have been trying to find for myself.
but my heated seats seem only to work when they want and only for a minute or two.
have been trying to research but can not seem to come a cross a similar post please help!
Old Nov 25, 2020 | 03:08 PM
zacha.antho's Avatar
6mt Brembo pkg
https://www.nicoclub.com/infiniti-service-manuals
Check out the service manuals, you may find the exact information you need. I found the heater diagram there under Seats (03 Coupe). Seems like you should check the 10A fuse #38. It could also be a faulty relay, or temp regulator... in which case you would need replacement parts.
Old Nov 25, 2020 | 04:53 PM
cassa183's Avatar
Thank you for your help and time.
I have been trying to look thru the manual and can not make heads or tails of it lol.
I will check the fuses and relay as stated.
It is just very weird that they only work when they want and only long enough to feel them get warm and shut off
Old Nov 25, 2020 | 10:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There is a thermostat in the lumbar section of the seatback, temperature should fluctuate from 95F to 113F
Since the seats ARE WORKING the problem is not in either the power delivery circuit, the switch, the heating elements. Your problem definitely sounds like a thermostat issue and you might have failing thermostats or someone may have spilled something on the seatback or damaged it in some way.
Do BOTH seats exhibit the same problem?
Old Nov 26, 2020 | 07:05 AM
cassa183's Avatar
Yes they both have the same issue.
weirdest thing I have encountered with heated seats in general. Lol
Old Nov 26, 2020 | 10:02 AM
cleric670's Avatar
BANNED!!!
The light stays on the entire time on the switch though correct?
Old Nov 26, 2020 | 12:43 PM
cassa183's Avatar
Yes correct
Jacob_USA
Jul 21, 2009 06:57 PM
scdgoofy
Sep 7, 2005 12:16 PM
fotodad
Dec 7, 2004 09:39 PM
GforceI
Apr 3, 2003 10:36 PM
