19" oem rays fitment advice needed
May 4, 2021 | 12:19 AM
Hey guys I'm looking to get coilovers by this summer and I plan on running my oem 19" rays. I'm feeling a little confused, a guy I follow on Instagram (@shtaticg35) has pretty much the fitment I'm looking for. He's on coilovers with 50mm spacers on the rear and 40mm spacers on the front (I'll attach a screen shot). He has stretched tires which I don't plan on running. My tire setup is currently 235/40 R19 front and 245/40 R19 rear. I plan on running Raceland primo coilovers which are rated for a 2-4 inch drop, I'd like to go as close to 4 as possible. My fenders are already rolled so more aggressive sized spacers would be an option. Would 30mm spacers all around work or would I still need more? If so what are some good brands for spacers over 30mm? I was originally planning on buying spacers from z1 motorsports which carry up to 30mm. I know my setup probably won't look exactly like this, but I'd like to try to at least get close.
shtaticg35 setup:
Reply 0
May 6, 2021 | 09:34 PM
I strongly recommend getting the coilovers installed to the height you like FIRST, then align the vehicle, then just measure actual clearance for the spacers and order them at the end.
Reply 0
May 6, 2021 | 09:36 PM
Quote: I strongly recommend getting the coilovers installed to the height you like FIRST, then align the vehicle, then just measure actual clearance for the spacers and order them at the end.
That's a good idea. Thank you!
Reply 0
