04 g35 driver side headlight not working
Old May 4, 2021 | 09:07 PM
2004g35.'s Avatar
G35
I have a 2004 g35 coupe. I bought new headlights and headlight ballast. When I first turn my key both lights will turn on but if I keep my vehicle running and shut my lights off and turn them back on the driver side low beam doesn’t turn on. Any one know the problem ?
Old May 6, 2021 | 10:04 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Swap components one at a time from the driver to passenger side until you isolate which component is the problem.
I would start with the ballasts.
Old May 7, 2021 | 01:00 AM
2004g35.'s Avatar
G35
I put brand new ballasts on each side that’s not the issue. It’s only my low beams everything else works fine. Idk what else it could be besides wiring
Old May 7, 2021 | 07:24 AM
telcoman's Avatar
Veteran: Army
That doesn't matter
Follow Cleric's advice
Just because a part is new doesn't mean it is good. Haven't you ever heard of out of box failures? Quite common.
Old May 7, 2021 | 10:45 AM
cleric670's Avatar
BANNED!!!
Did this problem exist BEFORE the new lamp/ballast? From your post it sounds like you put in the new lamp/ballast then the lights started malfunctioning. Clarify.
The reason for swapping the components, you might have purchased a DEFECTIVE "brand new item", the logical troubleshooting steps are to start swapping components that are known to work (i.e. the other side of the car) with the side that is currently malfunctioning.
Once you have swapped the ballast, driven and verified the problem still persists, then swapped the lamps, driven and verified the problem still persists, THEN you have eliminated those two components and being faulty. At that point you can start diving into the harness.
There is also a ground wire for each headlight that you should unbolt, wire brush the lug, bolt, and the chassis surface, apply a small amount of electrical anti-oxidation grease (not dielectric for spark plugs...), then bolt it back together. The grounds are located in the engine bay on the front of the wheel wells, small gauge wire on a ring terminal bolted to the wheel well.
Old May 7, 2021 | 07:57 PM
2004g35.'s Avatar
G35
I thought the same thing with the new ballast being defective so I ordered another new one and it did the same thing. I’ll have to try re grounding it and get back to you on that thank you
BigOgre
Lighting
Feb 11, 2014 05:12 PM
lilstev
Archived Sales
Feb 5, 2010 07:37 AM
VladBostonRUS
Dec 18, 2008 09:15 PM
elpibe
Dec 5, 2008 09:35 PM
