What should I change when starting a car that's been sitting for two years?
Old May 29, 2021 | 12:55 PM
fcp4life's Avatar
04 G35 Coupe Black Obsidian 6MT / Brembo Brake Package
I know that new oil and a filter is number 1. My G35 coupe has been sitting for almost two years while it was getting "fixed" Anyway I have it back so what should I change along with the engine oil and filter? Coolant? Should I remove the old gas and put some fresh new shell gas? and any additives that are recommended?
Old May 29, 2021 | 01:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just pump all the gas out and fire it up, oil and gas are the only two really important ones. You might have some injector issues that should clear up over the first few miles.
Definitely don't run it with that old gas in it though. Check all the other fluid levels, check tires for any cracking/rot, and tire pressure. Brakes will be bad for the first couple stops so be ready for it.
Also, highly recommend cleaning the windows before driving, it's crazy how much crap builds up on the INSIDE of the glass over two years.
Tires will probably be flat spotted for the first few miles, should clear up though. I wouldn't do anything highway speed until you've put a few city miles on the car just to make sure you don't have a tire about to die, better to lose one at 35mph than 70mph.
Ohh and check your lugnut torque, no telling what's been going on for the last 2 years.
Old May 29, 2021 | 01:19 PM
fcp4life's Avatar
just shove that tube down the fuel filler door into the tank and pump it out? I've read that you can drain it through the fuel pump.
Old May 29, 2021 | 08:33 PM
cleric670's Avatar
BANNED!!!
There's a couple ways, disconnect the fuel damper at the engine and pump out there by bypassing the fuel pump relay (make a jumper that goes to the battery positive), however it's easier to pull the fuel pump (and sub pump) and siphon directly from the tank with a hose though.
Two pull tabs on the rear seat at the front right where the cushion meets the floor carpet, one for each seat, pull them both forward then lift the front of the seat up and it pulls forward to unlatch. Takes about 10 seconds. Then you can unbolt the flange for the pump and sub pump (one on each side of the car) and siphon out the saddle tank. Bolt the flanges back down to 20 INCH/lbs.
Put down a couple old towels or rags so you don't get fuel on the carpet.
You can put a hose down the fuel fill neck but you always risk bending the float arm (my car was siphoned by someone and now I have a fuel level high input code when I have a full tank), plus you're only siphoning out half the tank and I think the driver/left half is not going to backfill the passenger/right/fill neck half because of the venturi configuration in the tank.
bluedevils95
Jul 20, 2016 12:30 AM
ClwMike
Jul 23, 2015 12:55 PM
Karman
Dec 10, 2007 10:49 AM
redwillow
Jul 11, 2003 11:16 PM
