Bad performance and rough idle when fully warmed up engine
Old Jun 11, 2021 | 01:36 PM
ab.1way's Avatar
full options , has the fx35 engine
Hello boys hope yall doing great, unfortunately i have no good mechanics around me so i had to ask on the forum, my problem is that the car runs amazing when i first start it and warm it up a little , she’s a ****ing rocket , then after like 30-60 minutes of driving she starts to lose power specially on low rpm acceleration, the loss of power is noticeable in addition to a kinda shaky idle i can feel the car being jerky when trying to slow down before a redlight or a speed bump, to give you more info on the car , it’s an 03 g35 coupe my h02 and air fuel ration sensors are deleted, in addition to codes appearing on the scanner such as , closed loop bank 1 and fuel temperature sensor A high temp , if anyone could offer some help that would be amazing , thanks in advance
Old Jun 11, 2021 | 06:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I didn't even think these cars would operate except in limp mode if you didn't have the upstream O2 sensors plugged in.
Fix the O2 sensor problem to start with, you NEED the upstream ones that's how the car knows how much fuel to deliver. Downstream sensors are just catalyst efficiency sensors and you can trick them with non-foulers.
Then go after whatever broke on the fuel pump that's giving the fuel temp high resistance code.
Then pull the spark plugs and inspect for wear.
Old Jul 15, 2025 | 01:06 AM
Pestilentking's Avatar
Track car
My question is have you checked for vacuum leagues have you checked to see if there's any noticeable oil leaks around the top of the cam covers or the bottom of the oil pan do you smell anything funny.?
Old Jul 16, 2025 | 08:20 PM
MaLPoPieS's Avatar
Jaguar XFR-S
You do realize that you're replying to a 4 year old thread, right?
Old Jul 16, 2025 | 08:50 PM
Track car
Damn it lol 🙄🙄🙄🙄
Old Aug 27, 2025 | 08:00 AM
Jhoop23's Avatar
What would it mean if there was oil was leaking around top of oil pan and onto of camshaft sensor
Old Sep 2, 2025 | 07:57 PM
jbarnett250's Avatar
It would mean your engine is in upside down.
Old Sep 2, 2025 | 11:16 PM
MaLPoPieS's Avatar
Jaguar XFR-S
and you would think that God created a human with a brain that can understand the basics of gravity.. Gosh!
Hollipeter
Jul 15, 2025 01:13 AM
Jacobk4508
Feb 11, 2017 12:13 PM
Jacobk4508
Feb 7, 2017 12:08 PM
nukepharmer
Forced Induction
Jul 20, 2006 12:10 AM
TomekZdano
Nov 2, 2005 09:49 PM
