Code p0302 trouble
Old Jul 12, 2021 | 12:04 AM
Beaverhunter121's Avatar
Test pipes, aftermarket y pipe, magnaflow catback exhaust, intake
Code p0302 trouble
About 3 days ago my 06 g35 coupe was misfiring decently at idle but not throwing a code, decided to change out my spark plugs the same day. Today after i was out maybe 20min it started to misfire again at idle, then while i was giving it throttle on the drive home it bogged like crazy in 4th and the cel started blinking for the p0302 code. Injectors? Coil packs? If anyones got experience with an issue caused by this code
please let me know.
Old Jul 12, 2021 | 08:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you replaced the plug, and there was no oil in the spark plug well tube, then it's fairly safe to assume the problem is the coil pack. You can unplug a couple coil packs and use a digital multimeter to measure resistance across the pins and compare to cylinder 2 which is throwing the P0302 and more than likely there is a different ohms reading on the cylinder 2 coil pack.
You can also take the coil pack and swap it with another cylinder to see if the error switches to another cylinder.
P0300 is random misfire, if the last digit has 1-6 that corresponds to a specific cylinder.
P0304 is cylinder 4
P0302 is cylinder 2.
Rainy
May 5, 2021 11:06 PM
IVAN S.
Oct 4, 2020 10:34 AM
cfauvel
13
Oct 31, 2016 09:14 AM
jim9
Sep 14, 2012 02:27 AM
High3nd_SD_g35
11
Jun 16, 2008 04:01 AM
