Help with exterior door handle?
Old Jul 18, 2021 | 06:25 AM
elainelorie's Avatar
infiniti g35 DE coupe
Howdy,
I just finished wrapping my g35 and I can’t seem to get the passenger door handle screw to align back with the part I need to screw in… It hasn’t been on for about a week( I finished wrapping the doors about a week ago and I haven’t been able to figure out the handle situation), I can still open and close the door.
if you think you have a solution for me I would appreciate a dm on ig @ elainelorie
not quite sure how this site works
Torx screw that won’t line up
I think it seems to be hitting to the left ? From the wear of it
turns out that the bolt housing had been pushed in. Fixed my problem 🥰 idk if anyone will ever read this or have this problem, but if you do have the same problem, push your bolt in hard with the screwdriver (your goal is to move the whole bolt housing forward so it locks into the original position)
Last edited by elainelorie; Jul 18, 2021 at 06:55 AM. Reason: Fixed my problem before anyone could help
Old Jul 7, 2022 | 11:13 AM
frankov04's Avatar
06 g35 coupe
Torx screw
I just finished wrapping driver door and have the same issue can you elaborate more on the fix
gaugedgc
Apr 17, 2015 11:35 PM
Patrick Doherty
Jan 22, 2013 02:42 PM
dimsler
Feb 28, 2012 04:54 PM
lankanrascal
Sep 4, 2011 09:55 PM
