Can't find location of the leak.
Old Jul 30, 2021 | 03:05 AM
humbalum's Avatar
Infiniti G35 Coupe 2005 Gray
Question Can't find location of the leak.
I've been having trouble finding my oil leak, from pictures I would assume that the gasket on my transmission pan and the pan should be replaced as well. But I did hear that bad valve cover gaskets could also be a symptom that leaks down. I will look further in on the leak but I want to know if it could be the valve covers that might be the issue. Thanks
Old Jul 30, 2021 | 10:33 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get an inspection mirror and a good flashlight and look around for the leak. Sounds like you're not using an inspection mirror.
Shine the flashlight ON THE MIRROR and it will reflect the light where you're looking. Takes a little practice but this is how you find leaks on cars.
EDIT: I recommend a 2" mirror, not the smaller ones.
Old Jul 30, 2021 | 01:50 PM
humbalum's Avatar
Okay so to follow up, I've went under the car right under the dripping spot and found out that above the gasket of the pan is completely clean and dry. Making me believe that it's likely a leak on the gasket.
Old Jul 30, 2021 | 02:19 PM
cleric670's Avatar
BANNED!!!
Make sure to check all the way around the pan, oil can hit that seal at the lower pan gasket and work all the way around it to drip at an entirely different location.
What happened to your exhaust?
Old Jul 30, 2021 | 02:29 PM
humbalum's Avatar
Lol the cats were stolen, sounds like a v8 now.
Old Jul 30, 2021 | 02:51 PM
humbalum's Avatar
Gonna get some test pipes and a new y pipe, hopefully easy install.
Old Jul 31, 2021 | 01:04 AM
humbalum's Avatar
I want to update on this post, I noticed the drip was actually coming from this one bolt and it was almost finger loose. I went ahead and tightened it and it seems like it has stopped dripping. I might use some locktight on it in case it comes loose again during the ride. Not sure why that one bolt was very loose.
pdexta
Dec 6, 2017 07:58 PM
jessex35
Mar 16, 2016 09:10 AM
whoisthis
Southern California
Jul 23, 2012 12:47 PM
supG35x
Mar 16, 2012 11:57 AM
Mr_pharmD
Forced Induction
Jan 23, 2008 09:49 AM
