Leaking Oil
Old Mar 9, 2012 | 04:15 PM
supG35x's Avatar
Leaking Oil
I went to two different mechanics and they both said
YES there is a leak and it is caused by cracked Valve Cover Gasket.
is it popular for vd35 engines to have this problem when its over 100k miles?
Anyways, they are both quoting me for 480 to 500 dollars....(300 labor 180-200 for parts.)
i was expecting to pay around 300 with everything but i guess not....
hmmmmm.... any place i can get the gasket for less?
Thanks
Old Mar 9, 2012 | 04:28 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The gaskets are only $13-16 for each side. You need the entire valve covers to be replaced as well. It is not common for the valve cover gaskets to leak, however it is very common for the spark plug tube seals located in the valve cover to leak.
I am purchasing both side valve covers and gaskets for $395 from OC Infiniti (a vendor here on the forums) and installing them myself.
A reasonable price to fix your car would be around $600 if you're at a shop with the average $100/hr labor rate.
Old Mar 9, 2012 | 04:46 PM
supG35x's Avatar
dang, can i just replace the gasket? i did read some forums from here stated it is okay to just replace the gaskets.
my car only has 100k miles. T_T
Old Mar 9, 2012 | 05:00 PM
JaE35's Avatar
Moderator
G35 Sedan
did you search any at all on this? Tons of information available
Old Mar 13, 2012 | 03:38 PM
supG35x's Avatar
I finally found a mechanic who is willing to do it for 400 and thats with everything!!! (labor + parts)
I think i got a deal here lol
Old Mar 13, 2012 | 07:58 PM
bluedevils95's Avatar
Thats good. How long will it take to fix?
Old Mar 16, 2012 | 11:57 AM
supG35x's Avatar
3 hours not bad at all
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
vamarris
Sep 26, 2015 12:56 PM
