05 G35 limb mode
Old Sep 10, 2021 | 10:28 AM
chrisg05's Avatar
rev up coupe g35 2005
Exclamation 05 G35 limb mode
alright i have a 2005 g35 coupe rev up
the car has a issue going into limb mode wont go over 2500 rpms its throwing codes but im not a 100% sure on what to try first the codes its throwing are
P1274
P1283
P1271
P1274
P1781
P1283
just trying to get some others opinion before i start take things apart and trying to fix them
Old Sep 10, 2021 | 12:44 PM
telcoman's Avatar
Veteran: Army
P1274
P1283
P1271
P1274
P1781
P1283
Here is the FSM for your vehicle
https://www.nicoclub.com/service-man...F2005%2Fec.pdf
DTC P1271, P1281 A/F SENSOR 1 PFP:22693
Component Description ABS00A4A
The air fuel ratio (A/F) sensor 1 is a planar dual-cell limit current sen-
sor. The sensor element of the A/F sensor 1 is the combination of a
Nernst concentration cell (sensor cell) with an oxygen-pump cell,
which transports ions. It has a heater in the element.
The sensor is capable of precise measurement = 1, but also in the
lean and rich range. Together with its control electronics, the sensor
outputs a clear, continuous signal throughout a wide range (0.7 <
< air).
The exhaust gas components diffuse through the diffusion gap at the
electrode of the oxygen pump and Nernst concentration cell, where
they are brought to thermodynamic balance.
An electronic circuit controls the pump current through the oxygen-
pump cell so that the composition of the exhaust gas in the diffusion
gap remains constant at = 1. Therefore, the A/F sensor 1 is able to
indicate air/fuel ratio by this pumping of current. In addition, a heater
is integrated in the sensor to ensure the required operating tempera-
ture of 700 - 800°C (1,292 - 1,472°F).
DTC P1273, P1283 A/F SENSOR 1
EC-491
C
D
E
F
G
H
I
J
K
L
M
A
EC
Edition: 2004 September 2005 G35 Coupe
DTC P1273, P1283 A/F SENSOR 1 PFP:22693
Component Description ABS00A4O
< air).
What were you doing to your vehicle prior to all of these codes?
Old Sep 10, 2021 | 07:49 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Well since you're throwing O2 sensor codes for both banks and it's a LOT of codes you may have blown the O2 sensor power circuit (thanks Seymore learn new stuff every day).
Start by checking the IPDM fuses, not sure of the circuit numbers, check the FSM.
https://www.nicoclub.com/infiniti-service-manuals
islandvol77
Jul 21, 2016 09:53 PM
JMSABO
Feb 6, 2015 11:52 AM
RomoG35
Oct 22, 2009 04:58 AM
huyqvu
Apr 13, 2009 03:22 PM
kleva
Jun 16, 2008 01:08 PM
