Got a p1124 code NEED HELP
Old Mar 14, 2022 | 09:25 PM
MulishaG35's Avatar
coupe 6MT
Code P1124 is Throttle control motor relay, but how do i fix it? Slip and VDC light is on, cant rev pass 1500rpm.
replaced both camshaft position sensor and the crankshaft position sensor, did the ecu reset and throttle body relearn and everything seems fine until i start the car again
little back story, i was replacing all my 02 sensors and when i went to start the car it wouldnt, so i tried replacing all the fuses that i can and it turned out to be a ground wire on the front timing cover being ripped off.
Old Mar 18, 2022 | 11:48 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did you replace the cam/crank sensors with OEM Genuine Nissan Parts, or Hitachi (the OEM supplier)? If not I strongly recommend putting the factory cam/crank sensors back in because aftermarket sensors are HIGHLY notorious for not working properly.
As for the code, throttle control RELAY, it's located in the IPDM fuse box. Swap it with the AC relay to see if that code goes away (which would make the AC not function if it was actually bad).
Just be sure to identify which relay is which before you start unplugging stuff, take a sharpie and just write on the top of it.
AntonyH
Feb 5, 2019 06:59 PM
frankywashere
Oct 2, 2016 09:26 AM
VQSTONE
Dec 9, 2013 09:34 AM
GTRDHybrid
Jun 2, 2010 01:06 PM
