Car dies after sitting for 24 hours
Old Mar 21, 2022 | 08:52 AM
TheSushi's Avatar
Grey '04, manual and sends
Exclamation Car dies after sitting for 24 hours
If I leave the car sitting for even 24 hours, the battery dies. OEM Bose amp and head unit installed, kill switch hooked up to the fuel pump by previous owner. Any ideas what might be causing it or anyone experience something similar?
Old Mar 21, 2022 | 02:17 PM
909's Avatar
909
Your mom's boyfriend
Test the battery
A voltmeter costs less than $10
Lead acid batteries should never go below 50% SOC ( state of charge)
To make this easier to understand:
12.0 volts = 0%
12.35 volts = 50%
12.7 volts or higher = 100%
Remember anything below 12 volts causes permanent damage.
Old Mar 21, 2022 | 03:24 PM
telcoman's Avatar
Veteran: Army
Originally Posted by 909
Test the battery
12.0 volts = 0%
12.35 volts = 50%
A battery hydrometer is also around $10 and can show a weak or a defective battery cell not accepting a full charge
Old Mar 21, 2022 | 03:31 PM
TheSushi's Avatar
i started it this morning, just to see if it start, it did, turned it off, then 10 mins later came out and it didn't have enough juice to start again.
so i let the car sit all day while at school (7 hrs) and i got a reading from it when i got and its at 9.75V lmao.
this isn't looking too bright
I'm charging it up rn, waiting for it to get fully charged then seeing the voltage drop after a couple hours
Old Mar 25, 2022 | 02:12 PM
Scorpi0's Avatar
I think the Bose amp and head unit were notorious for going bad and sucking power til the battery died. Un plug the Bose amp and test again to see what happens.
Old Mar 25, 2022 | 07:36 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like a bad battery if you can't even restart the car after sitting for 10min.
Old Mar 28, 2022 | 02:09 AM
909's Avatar
909
Might want to invest in a jump starter ( external battery) or a new battery (if you plan on keeping it) .
EH1957
Sep 6, 2019 05:48 PM
KingoftheRoad1
Sep 25, 2013 05:35 PM
cackiantors
Audio/Video/Electronics
Jan 26, 2011 04:26 PM
shakin
Apr 7, 2009 04:14 PM
