Door locks acting funny
Old Aug 6, 2022 | 04:10 PM
Zeromaz's Avatar
clean
My door locks are struggling. Plus unlock on the car and the lock will move a tiny bit, but won’t actually unlock the car. Sometimes it happens the other way around. Lock the car, horn sounds, alarm turns on… but the car doesn’t actually lock. I live in a hot climate if that matters. Anyone have any idea whats going on here?
Old Aug 6, 2022 | 04:28 PM
HoserG35's Avatar
G35 6MT “Brembo Car”
One of the most well known problems of the car, weak lock solenoids.
Old Aug 6, 2022 | 05:12 PM
2003G35stock's Avatar
G35 Manual
replacing them is a bit of work, here's a video:
Luckily, parts are fairly cheap, here is an example
https://www.carparts.com/details/Inf...E&gclsrc=aw.ds
This is how they die, they simply move less and less. haven't had to do it yet on my G35, but I have done these on a lot of cars over the years, they all die. Not a lot of fun but necessary
Old Aug 8, 2022 | 04:36 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
https://www.youtube.com/watch?v=ZYPi...SAN%26INFINITI
I think the actuator you linked to is for sedans only and that the coupe uses a different (and more expensive) one. I don't recall seeing the actuators themselves available separately for the coupe, it's usually the entire assembly. I'd love to be wrong because both of mine could use replacing. I've also seen write-ups here of generic actuators made to work on the coupes, but personally it's a bit sketchy for my tastes.
Old Aug 8, 2022 | 04:57 PM
G35 Manual
I see what you mean:
https://www.z1motorsports.com/door-l...xoCWmMQAvD_BwE
Now I am confused as the Infiniti dealer site shows the original item as well. But I can see the assembly doesn't have this piece. Apologies.
Old Aug 9, 2022 | 03:55 AM
Scorpi0's Avatar
My door locks will get weaker if I keep cycling them like 5 or 6 times in a row.
And if I park my car with the driver door facing the hot sun for a few hours, that lock will stop working til it cools off.
Old Aug 9, 2022 | 12:36 PM
G35 Manual
Yeah, that's the actuators. This is so common with cars today. I've replaced them on BMW, Hondas, Toyotas, Chevy's, whatever. They last a good decade then start to get slow. At 15 years they are often done. And they are never in an easy place to just pop out. On my camaro, it's riveted in, so you have to actually drill it out. Bleh.
Rattpack boi
Feb 27, 2014 03:23 PM
infinitigman35
Jan 15, 2014 12:22 PM
cpufreak3
Jun 15, 2009 05:50 PM
Nasty09
May 15, 2009 02:35 PM
robswid
Jul 19, 2007 01:46 PM
