How well does stock oil cooler perform?
Old Aug 6, 2022 | 05:00 PM
2003G35stock's Avatar
G35 Manual
hello all,
Has anyone measured how the stock oil cooler does overall? it only comes to mind as I sit here looking at it while I was putting it back on (new oil cooler seal was put on). It seems so different from aftermarket, since I don't even see where the coolant goes to, usually aftermarket it goes straight to a secondary radiator for it. But I guess this goes somewhere else.
I'm on this part of the car right now, also fixing the oil pressure sensor I broke, and I see the wire leading down to it needed to be heat sleeved, it's right next to the alternator. And I spun on a new oil filter while doing all that as well.
Thanks for any info people might have found
Old Aug 7, 2022 | 12:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's a coolant/oil heat exchanger, not an actual oil cooler.
The coolant loop FROM the engine feeds the oil cooler, which then feeds back into the engine loop at the thermostat, I would say it's decent for short bursts but even a cheapo aftermarket oil cooler will be SUBSTANTIALLY better.
A lot of the heat exchange will depend on your radiator, for example I put in a bigger aftermarket radiator which provides significantly better cooling. Therefor the oil heat exchanger will always be able to work as efficiently as it can because coolant is always going to be a stable temp.
Highest I hit was 247F and that was on a day when the ambient temp in the shade was 115F. Granted that's still REALLY hot oil and if I was doing that regularly I would definitely be installing an aftermarket cooler. That was my 4th lap and I was starting to lose my brakes anyways (wasn't on super aggressive pads).
Old Aug 10, 2024 | 02:04 AM
alex7x8's Avatar
G35x
I guess to make oil cooler more efficient you can add something like transmission oil cooler in the coolant line between cylinder head output and oil exchanger.
It should drop antifreeze temperature for oil exchanger by 20F or so.
Joenavy85
V36 Engine, Exhaust, Drivetrain & FI
Mar 27, 2019 09:45 PM
whoisthis
Apr 9, 2013 09:02 AM
texasmax
Mar 11, 2010 04:11 PM
FiveSeven SS190
Jul 7, 2008 05:45 PM
ARH_twilightblue
Feb 18, 2005 04:48 PM
