ABS/VDC/SLIP/CEL Lights All On. 9 codes total.
Old Aug 22, 2022 | 06:30 PM
cabatchi's Avatar
dinged up non-rev up 2005 6mt (pretty much stock other than some scuffed AODHANs)
Originally Posted by 2003G35stock
Orange wire, I believe you should see it under the dash, I've attached a pic someone else took of where it leads. Check there and then back to the fuse box for the 40amp fuse (I'm pretty sure it's 40amps). In this picture, the person was installing in a switch to disable it rather than just cut it.
how would I get to the wire? take off the dash? sorry for the questions I'm a bit dumb
Old Aug 23, 2022 | 02:24 PM
2003G35stock's Avatar
G35 Manual
Look under the dash. You see that thing to the left of the wire? That's the brake/clutch/pedals area. You should be able to just upside down from the drivers seat to see it.
Old Aug 23, 2022 | 02:28 PM
cabatchi's Avatar
appreciate it, will look at it once I'm feeling better. I really do hope you know how much I appreciate your guys' help lol
Old Aug 25, 2022 | 12:58 PM
cabatchi's Avatar
Checked, couldn't find anything with my limited knowledge of wiring.
BUT
I'm wondering if the fusebox will go off of the 2004 fusebox diagram or the 2005 fusebox diagram. On the 2004, slot #88 is for the vdc/slip/abs system (10A), while on the 2005, it's for the front fog lights (15A). Should I be slotting in a 10A fuse in there or a 15A?
Old Aug 25, 2022 | 03:10 PM
G35 Manual
Put the 15 in for now and for checking the system. You can swap it out later.
Old Aug 25, 2022 | 03:14 PM
cabatchi's Avatar
there's a 15A in there right now, might try a 10A whenever I get my hands on more fuses
Old Aug 27, 2022 | 04:23 PM
cabatchi's Avatar
where do people get their fuses from?
Old Aug 27, 2022 | 05:27 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Anywhere, auto parts houses, online, Home Depot. All usually carry standard minis.
Old Aug 27, 2022 | 06:05 PM
cabatchi's Avatar
appreciate it
Old Aug 27, 2022 | 09:18 PM
cleric670's Avatar
BANNED!!!
Also, anytime I'm at a pick-n-pull and usually grab a handful of various ones since they don't normally charge me for them
rider164
Drivetrain
Apr 23, 2022 03:44 AM
AustinErkl
Feb 8, 2021 06:41 AM
Cvrlxsebruv
Jun 1, 2020 08:36 PM
legendaryoutlaw
Oct 31, 2019 05:20 PM
infinus
Jan 17, 2010 10:21 AM
