Limo mode
Old Sep 27, 2022 | 09:39 AM
MafiaChild94's Avatar
It's a stock G35 sedan
Limo mode
I have a2004 Infiniti G35 sedan and it shut down on me a few months ago. A friend and local mechanic ran a test and it shows as a P4 code? I'm not to familiar with codes but I wanted a second opinion. The car won't start. Was driving it when it just shut down. It wants to start but won't turn all the way over. Any ideas?
Old Sep 27, 2022 | 05:21 PM
2003G35stock's Avatar
G35 Manual
Does it turn the starter and make starting noises or it doesn't even click?
If there is nothing, then I would check things like the switch under the clutch pedal (if you are a stick) and also all the ground wires to make sure they are not broken, and also check all your fuses to see if anything popped.
The error codes are usually 4 digits, like P0430 . That particular code would be a cam sensor error. P4 without the rest doesn't ring a bell to me.
Old Sep 27, 2022 | 06:47 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Now I desperately want to see a G35 limousine.
As the other poster replied, that's not a valid diagnostic trouble code. It will be a letter followed by 4 digits.
First digit, P - Powertrain, C - Chassis, B - Body, U - Network
Second digit, 0 - generic, 1 - manufacturer specific
Third digit, 1 - fuel/air, 2 - injector, 3 - ignition, 4 - emissions, 5 - vehicle speed/idle, 6 - computer transmit error, 7 and 8 - transmission
Fourth digit combined with the third digit is your specific fault.
Post the DTC here.
infinity35
Jan 4, 2024 08:49 PM
dmeroff
Oct 28, 2019 11:22 AM
Starscream
Nov 30, 2015 09:29 AM
alan17
Mar 1, 2014 08:13 PM
ekrebs
12
Jan 31, 2012 09:22 PM
