Door lock issue- checking with the experts here
Old Jun 17, 2023 | 08:07 AM
shurur's Avatar
2003 G35 Coupe
Originally Posted by radioking
Priority for your 2003 G35 or your Audi ?
Thanks for the suggestion...
Audi....
Also make sure you get a quality actuator. That for me means a new oem part or used oem part from a good salvage vendor.
The actuator is a somewhat complicated electro-mechanical device that requires precision builds.
You are going to be taking everything out of the inner door to get at it. You don't want to be revisiting the job because of some cheap aftermarket part failing.
Old Jun 17, 2023 | 10:56 AM
radioking's Avatar
Originally Posted by shurur
Audi....
Thanks. I've been watching some videos, not that I can do it myself. I mean, maybe I could, but it would take a while and I'm sure I'd screw it up a few times :-( But I can see how everything gets removed. The OEM at Z! are expensive, but obviously the smart choice. Like I mentioned, I'll wait until I absolutely have to do it and then do the window and door together...
As always, thanks for the feedback. As frustrating as this car is, I keep looking around.... " What would I buy if I sell this ?" and I don't see much out there that I'm interested in. I don't have the wallet for Porsche, or the interest in American muscle :-)
Old Jun 17, 2023 | 11:57 AM
shurur's Avatar
2003 G35 Coupe
www.yourmechanic.com will have a mechanic fix it in your driveway while you get to watch.
The G is my wife's car, but she wants an SUV. Once that happens, the G is mine and I sell the Audi.
Old Aug 6, 2023 | 11:36 AM
shurur's Avatar
2003 G35 Coupe
AUDI was entire Summer...timing belt and all seals, motor mounts, all coolant hoses and hard pipe seals, valley pan gasket, oil check valves and seals, new sparks, cops,, injectors and connectors,,,etc....but I did not fix my door latch problem..
Interestingly the G just had the trunk latch fail yesterday
No switch or inner trunk cable would open it.
Latch was making noise, so that was good...
I used my palm to thump the trunk while using the key fob to finally get it to open.
Now two cars have a latch to fix, replace or degrease...
Old Aug 6, 2023 | 11:52 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Might just need some lubricant, spray some white lithium grease into it.
Old Aug 6, 2023 | 12:04 PM
shurur's Avatar
2003 G35 Coupe
For me..
Looks like it has never been lubricated!
I used some synthetic grease, as that is what I had around.
It works now, but trunk does not pop up like it did.
That could be dead trunk shocks or tired popup spring in lower catch..
I'll get some lithium grease and degreaser.
I have meaning to get some for a while now..
Old Aug 6, 2023 | 05:11 PM
cleric670's Avatar
BANNED!!!
You might hose it down good with some aerosol silicone or teflon spray first, those will get into all the little crevices better than the white lithium will initially. Avoid WD40, it's just going to attract dirt, silicone, teflon, and white lithium are pretty good about not attracting dust/dirt.
terrasmak
Oct 26, 2021 08:29 AM
Rattpack boi
Feb 27, 2014 03:23 PM
SMOOTHYG35
Nov 22, 2012 11:43 PM
saltyload
Aug 11, 2012 05:22 PM
