2005 Parasitic Battery Draw from Radio
Old Mar 31, 2024 | 02:59 PM
T_Vulture13's Avatar
Would appreciate any help or advice on next steps in diagnosing/fixing this issue:
- Noticed battery (~4 years old) would drain if car was not driven for a few days
- Battery checked by the mechanic and the battery is not the issue
- Battery still charges fine, alternator is not the issue
- Performed a parasitic draw test using my multimeter and found that the battery was pulling >400 mA with a lot of noise when off
- Checked fuses one by one and found that the main culprit was the 15A radio fuse
- Disconnected the radio fuse and battery drain dropped to a steady 100 mA (which I think I've seen is not great, but not bad)
Now that I've singled out the radio circuit as the biggest issue, any advice on next steps? I know I've seen some posts about re-soldering some of the resistors on the radio unit, but want to try to diagnose the issue further before trying that.
Thanks for any suggestions!
Old Mar 31, 2024 | 08:04 PM
Scorpi0's Avatar
U sure its not the amplifier that is drawing the current?
Maybe ​​​​​​@Wrathernaut might have an answer.
Old Apr 7, 2024 | 11:53 AM
@Scorpi0 hmm, it certainly could be, I haven't tested/tried to isolate which part of the radio circuit was drawing the current. I'll look around for threads on the amp drawing extra current.
Jayemem
Feb 11, 2024 12:12 PM
Sl33zyvq
Jun 19, 2019 07:19 PM
BlueBelleG35x
Mar 10, 2019 01:48 PM
celwin
Jan 8, 2018 11:15 PM
KsuMax
May 15, 2009 01:44 AM
