The definitive solution to sticking clutch and bleeding problems
Old Jun 1, 2024 | 08:27 PM
Alexkf's Avatar
g35 MT
If your clutch pedal is sticking (not returning all the way back)
OR
If you have replaced your slave cylinder hose and/or slave cylinder and cannot bleed the system via conventional pump-and-bleed process
OR
If you believe you replaced the clutch fluid but it didn't help the pedal sticking
The problem is you actually did not replace all of the old fluid and did not fully bleed the system
The solution is 2 extra steps BEFORE conventional pump-and-bleed process
STEP 1 - Bleed the slave cylinder in the opposite direction
-Build some pressure in clutch pedal if possible (remember to wait 5 seconds every time you bring the clutch pedal all the way back up)
-Insert a wooden stick between clutch pedal and driver's seat so that the clutch pedal is fully depressed to the floor
-Get under the car
-Take any tool with a bulky metal handle such as a ratchet
-Firmly press the tool on the clutch fork with one hand, open the bleeder valve
-Keep pressing and push the slave cylinder rod all the way inside the slave cylinder
-You will see old fluid and trapped air will come out of the slave cylinder
-Repeat STEP 1 until slave cylinder doesn't have any old fluid left in it
STEP 2 - Overnight clutch depress
-Build some pressure in clutch pedal (remember to wait 5 seconds every time you bring the clutch pedal all the way back up)
-Wait at least 8 hours
-Slowly release the clutch pedal (remember to wait 5 seconds after you bring the clutch pedal all the way back up)
-You now have a functional clutch pedal
STEP 3 (Important)
-Do conventional clutch pump-and-bleed with a helper or a wooden stick
Hope this helps someone
I've seen everything from adjusting the pedal out of spec to replacing perfectly working master and slave cylinders
The problem is AIR and OLD FLUID in the system with a reduced boiling point
athens_murder'd
Jul 16, 2022 02:40 PM
patboos44
Drivetrain
Oct 17, 2017 12:33 PM
smokincoupe
Drivetrain
21
Jun 1, 2010 03:20 PM
perfectmax
Drivetrain
32
Nov 29, 2008 10:39 AM
JZ39
Mar 14, 2005 07:06 PM
