G35 coupe 6mt cranks but no start
Old Aug 31, 2024 | 10:48 PM
Chow_g35's Avatar
G35 6mt stock besides intake
Hello my g35 coupe shut off on me on the way to work and won’t start, I had it towed home and it’s definitely something with the crankshaft position sensor (rpm gauge doesn’t move when I crank the engine) 3 weeks ago had the same issue and I changed the cam and crank sensors, so this time I figured it was because I didn’t use oem or hitatchi brand so I put the original cam sensors back in and but a hitachi crank sensor in but still not cranking
I don’t know if it’s related but my g has been having electrical issues for about 2 months. Dome lights sometimes work, no running tail lights, no turn signals and now my window switches don’t work
replaced the crankshaft position sensor plug and wires still nothing
Old Sep 2, 2024 | 07:40 PM
G2B35AGN's Avatar
Any chance you have water in the IPDM underneath the battery? Somewhat common issue. Drain holes plug with debris, and voila, wet electronics. Pull the battery and see what you see....
Old Sep 4, 2024 | 01:02 AM
Chow_g35's Avatar
I checked that I’ve had the battery out a few days now drain plugs are clear and there’s no sign on moisture in that area
Old Sep 4, 2024 | 01:18 PM
Daebwylin's Avatar
G35 coupe
Same issue here with crank only but no start
I recently changed both camshaft and the crank shaft sensor, also replaced the battery and starter and lastly the fuel pump. After I replaced the fuel pump it starts ONLY ON COLD. If I drive the car for about 15 minutes and turn it off it would only crank when trying to start. When the car does run it runs perfectly fine. My car only starts when its cold start but yesterday when it was 98 degrees outside and the car was “cold” it didnt want to start. PLEASE HELP My car has been down for 2 months now. I also replaced the ipdm and checked all fuses and relays. Not sure what else to do…
kodiak341
Jan 1, 2023 12:45 PM
OnemeanG
Jun 25, 2021 01:47 PM
G35-R
Sep 22, 2020 02:08 PM
aptony
Feb 1, 2015 11:40 AM
sabino787
Sep 27, 2014 11:07 AM
