Please help slip light vdc check engine
Old Jan 23, 2025 | 02:23 PM
hyphel's Avatar
G35 welded lsd diff
The cars previous owner welded the lsd I pulled one off of a z.will changing this out stop those lights from coming on? I have to smog my car (I'm in California)to register it.i need help asap.
Old Jan 25, 2025 | 08:12 PM
G2B35AGN's Avatar
If you are really lucky, it's only that your brake fluid is low. Check that first. Otherwise, you need to pull the codes. If you don't have a reader, head to your local parts store. They'll pull the codes for free. If you need new sensors, buy only OEM or Hitachi (OEM manufacturer). Aftermarket sensors are a known issue.
Old Jan 26, 2025 | 12:24 AM
AnonG35's Avatar
It could also be your rear brakes are low. My VDC, Traction etc lights came on when rear brake pads were too low.
Old Feb 3, 2025 | 06:03 PM
hyphel's Avatar
G35 welded lsd diff
Obd codes
These are the codes if anyone can help me out
rider164
Drivetrain
Apr 23, 2022 03:44 AM
Mosesg35
Jul 26, 2019 09:13 AM
GM66
Jan 19, 2011 09:12 AM
kotched
Sep 23, 2010 01:26 AM
