P1283 code even after replacing o2 sensors, fuel pressure regulator, and some hoses.
Old Feb 26, 2025 | 05:18 PM
cabatchi's Avatar
dinged up non-rev up 2005 6mt (pretty much stock other than some scuffed AODHANs)
I recently took my car to the dealership because I need to get it smogged and can't figure out how to fix this code. Have changed o2 sensors multiple times, fuel pressure regulator, and plugs.
The dealership said:
"CONFIRMED CONCERN. FOUND ENGINE CODE P1273 A/F SENSOR1 B1.SMOKE TESTED VEHICLE AND FOUND PCV HOSE FROM AIR DUCT BOOT TO ROCKER COVER TO BE LEAKING. RECOMMEND REPLACEMENT OF THE AIR DUCT BOOT, PCV HOSE, AND RELEARN OF THROTTLE BODY."
They wanted $800 so I said no and decided to tackle it myself. Bought the hose set from z1 and replaced the items circled in this photo (not my photo)
I did the whole pedal dance to reset the ecu and did the throttle body relearn. After about 20 or so miles, the code P1283 was pending and after another 20 or 30 miles, my check engine light came back on.
I'm a little frustrated and worried because I need to get smog done by the end of the month. My mechanic friend who runs a shop actually told me to take it to Nissan after they had it in their shop for a week or two. After I sent him the service report he told me to just sell the car 😭
Any help would be appreciated, I am in the Sacramento area.
Old Mar 1, 2025 | 05:20 PM
cabatchi's Avatar
bump
Old Mar 5, 2025 | 12:02 AM
cabatchi's Avatar
bump 🙃
Old Apr 29, 2025 | 08:54 AM
Jeffreybonilla5's Avatar
Air and fuel mix error, cars running lean to mych air, check for exhaust leaks before the 02 sensors, check fuel injectors are working properly, do a smoke test to check for intake leaks
Old Apr 29, 2025 | 02:19 PM
cabatchi's Avatar
What would be a good way to check for exhaust leaks? My vaccum tubes are airtight from my testing but I'm not sure on how to test my exhaust
Old Apr 29, 2025 | 03:08 PM
U can always take out an o2 sensor and smoke it, or do it from the tail pipe, add smoke!
Jœrogan
Aug 4, 2023 11:31 AM
Jasper_
Jun 25, 2021 01:01 PM
g35madness
Apr 4, 2020 02:10 AM
PeteG35s
May 8, 2017 11:13 AM
Isayany
Feb 20, 2015 12:41 AM
